Question about Philips E-Box FTR9965 DTV Receiver
Looking for where to find this part
When I turn the tv on, it goes to red to green and then a half second later, it goes back to red. Does not respond. I've been told I need a ftr 9965 or ftr 9955 ebox for a phillips plasma. It is a 42" plasma. Please advise. Thanks, JOhn
Re: Looking for where to find this part
You need to fix power supply module (replace electrolitic capacitor on PCB) in your plasma. It's very frequently failure for this device.
Posted on Jun 09, 2008
0 characters
3 Points
After turning on the tv the green light comes on then it clicks back to blinking red after a few seconds
Issue with Logic Board Fail to innitial Voltage Safety Control Swich due to fails component inside TV Set... Please Refer To Certified TV Shop Repair ...
Oct 09, 2010 | Philips E-Box FTR9965 DTV Receiver
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | TV Receivers & DVRs
There is a switch on the bottom of the unit that has to be turned on. The power light will come on but not the screen until the switch is on.
Mar 27, 2010 | TV Receivers & DVRs
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
May 04, 2009 | TV Receivers & DVRs
Unable to switch my 15" LCD TV Receiver on
some tv sets dont come on when there is no picture signal in put, try and check your cables from the wall, aspecially connectors
Mar 24, 2009 | TV Receivers & DVRs
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | TV Receivers & DVRs
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Phillips plasma 42 in tv thin
malfunction of the vertical output integrated circuit
Dec 22, 2007 | Philips E-Box FTR9965 DTV Receiver
No startup
For my FTR9965, it is necessary to physically unplug the
power cord from the box before you are able to enter the service codes. The sequence is:
1. Unplug the box for a few seconds.
2. Plug it in again.
3. Turn on the box with the front panel power switch. Wait for the green light to come on.
4. From the remote, quickly enter 062596 plus the info key.
5. A message comes on the monitor warning you that you could really screw things up if you don't know what you're doing, and do you really want to continue? If yes, hit any button on the remote. You only have a few seconds to respond.
6. The "stand alone" option is near the end of the "service" menu list. When you find it, change the "no" to "yes".
7. Go back to the main SAM menu, scroll down to "Store", and hit OK. I'm assuming this makes the "yes" selection permanent.
8. Enter "00" to exit SAM.
Aug 08, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips E-Box FTR9965 DTV Receiver Logo
339 people viewed this question
Top Philips TV Receivers & DVRs Experts
Jaime Hernandez
Are you a Philips TV Receiver and DVR Expert? Answer questions, earn points and help others
