I have error 128 and i tried to reset the boiler but it is still flashing e128
Ariston boiler error code 501 only switched the gas meter of now boiler wont work
It is no flame detected. if gas meter was changed boiler should have been turned off . If this was not the case you have air in the boiler line which is try to purge out by the pilot which is a very small hole so this would take for ever .
Turn boiler of to try and reset it or you will have to purge boiler gas line .in the boiler .
Jun 09, 2018 | Water Heaters
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
I have a Worcester 24cdi combi boiler. When I put the hot water tap on, the water comes out cold. The hot water light on the boiler is flashing rapidly and the flame indicator light also flashes red. I...
i would take it back trade it in for a new one depending on how long you've had the boiler for, i ad the same problem with mine, so i brought mine back in they couldn't fine the problem so the gave me a new free of charge, also read the manual for that thing thats one thing i never did when i first got mine
Aug 16, 2013 | Heating & Cooling
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
