Question about Fujitsu Heating & Cooling
The code is high discharge temp
3 Suggested Answers
  • 910 Answers
SOURCE: 2008 fujitsu split a/c 24000btu
This code indicates a fault with the cooling system, in particulary the discharge pipe temperature sensor.
Posted on Jun 11, 2011
  • 3 Answers
SOURCE: fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Posted on Jan 08, 2012
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
Fan noise indoor unit (asu12rlq) fujitsu
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
All i know is that it indicates f6
F-6 out door unit high temp.Check condenser blocked? clean it If fan speed less rpm, replace capacitor. And then reset your unit. Now unit will run and no error code..
Dec 30, 2010 | Heating & Cooling
Error code Ch 07 ?
Ch-07 Splits = Compressor Over Current or discharge pipe temp high.
Reasons: LC condenser block-Clean it.
Less rpm of fan motor.-Replace capacitor.
Discharge temp sensor defective -Replace it.
Hope, is it helpful?
Dec 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
Ofm is running at half speed and compressor is not starting
The outdoor fan may operate at two speeds. The hotter the discharge air temp at the outdoor unit, the faster the fan runs. I would check the suction line and liquid line to see if they get cool when you call for cooling.It is very hard to tell if the compressor is operating since they are so quiet.
If this is not the case, you very well could have a bad capacitor,
Jul 09, 2010 | Fujitsu 18C1 Air Conditioner
Fujutsu mini-split 'discharge termperature abnormal' error code
This unit is what is called a Heat-Pump.It has a reversing valve in the condensing unit outside which switches you're system from cooling to heating via this valve.It has a ball bearing inside this that opens a port, and slides to close off another port to reverse the flow of freon from one season to the other.If your code indicates discharge supply air temp. abnormal, you are having a problem of some kind in your out door unit.Even though its new, I have seen these ductless split systems fail within a month. I'm am not saying that you have a lemon, just pointing out they do have problems with main board failures, Freon leaks at line connections because they are not brazed like systems with ducts. But, being this new, you should have this unit still under warranty!! For me to trouble shoot this online would be a long task, I would have to be on site. Call the Contractor now and get them out to make repairs right away. Compressor is normally a year warranty unless you get the 4 year Extention.Failures happen like this on all units, not just yours. It could be many small things that would cause a low discharge air temp. Get them back out!
Nov 12, 2009 | Kitchen Ranges
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
John Ray
Jun 30, 2009 | Panasonic SC-HT740 System
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
