Question about Ovens
I pulled the back off to check for voltage and now get no heat at all. I have 120v at each lead to heating element but do no get 240v when control is turned to bake
  • Ovens Master
  • 3,054 Answers
I'm Sorry Larry...
I have no idea why your question has remained in answered.
I tried to pull up schematic drawings on your KER?507
and got connected to a PDF site promising a drawing..
I have a COUPLE of life-times (now twice retired) reading
very high level "drawings" on stored program control
systems.. I just ran out of courage when the "site" looks
I have old MICRO-Soft everything... but if you know of any drawings ... I'd be happy to look into your trouble..
On oven wit no power (after removing the back... my FIRST GUESS would be a SAFETY INTERLOCK....
As to why you'd have good power & no heat... there are only two general possibilities...
1 - measure across the heating element itself for continuity.
2. After that TEMPORARILY short across HGH-TEMP sensor .out of your control circuit... if the element begins to heat it is the sensor... ELSE... It is the CONTROL BOARD
typically NOT cheap...
but there are REBUILDING SERVICES...
Please let me know if this is still an open question... and IF there is a decent DRAWING I can access.
KITCHENAID does have a (see very bottom)
technical support site... but WHEN I got there with my WIFE'S wine cooler..
They were LESS THAN... no help.
(not a happy KITCHENAID owner)...
(YOU go here... I only have a PC
(and my wife gets surly when I want to use her MACs))....
Posted on Jan 27, 2017
No heat in oven
Check outlet voltage, a 240v circuit breaker can trip halfway and not be visibly tripped when looking at the breaker panel... 120v will operate the oven controls, but will not heat the elements...
Apr 23, 2016 | Ovens
Oven will not heat, but burners still work
Without model number assuming burners on top and free standing unit.
The burners working tells you there is 240 volts to the unit. There are three possibilities, the bake element is burnt out, a wire is burnt off, a control part has failed. Bake elements can not be pulled unless the power is disconnected, because very often one side of 240 volts(120v) is wired direct so unplug, do not think having all controls off is enough. You can usually pull the bake element fairly easily by taking out two mounting screws and unplugging two wires. (these can go back on either way to the two terminals, does not matter just be sure tight) Take and have tested at appliance store, usually these test about 20 ohms. If that is good need to service from back and check voltages with a meter to find where problem in circuit is.....
good luck
Also check clock it is not accidentally in time bake setting, should be manual for most cooking (do this first before anything else)
Mar 14, 2010 | Kenmore Ovens
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Top oven will not heat all the controls are active, bottom oven works fine.
check voltage to element. should be 240v. if voltage is good then replace element.
Jun 21, 2009 | GE JKP27 Electric Double Oven
No volage at element posts.
your missing one 120volt leg,check your fuse/breaker panel then again at input terminals at unit and make sure you have a good neutral connection
Jun 19, 2009 | Ovens
Oven still wont heat up,after replacing thermostat,element checks
Check voltage at element while on. (dangerous) Make sure you have 240V across the two terminals of element. If not, then the control is the only thing left. Sound like the control has dropped one leg of power. Make sure you have 240 at the plug before removing rear panel.
Mar 17, 2009 | Ovens
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
Feb 25, 2009 | Ovens
My single glasstop oven
Will try to help here.. First off.. when you measure 120VAC at each terminal for the heating elements..what are you using as a reference? Ground? Since your stove is probably wired 220VAC, I would expect to see something across the two terminals to the element that isn't line voltage.. meaning, when you turn the controller to a setting, you should see something more than 120VAC across the terminals and the current will be controlled to maintain a heat setting. The burner that has an open element is indendent so that should not factor in. Heating elements are nothing more than a big resistor that generate heat when current flows thru them. Just because you have one leg of power doesn't mean you have current flow thru it and therefore that is where I think your problem is... You may have an open leg ..Check the power coming into the oven and make sure you have 220VAC across the two line voltage terminals.. Be careful ( very careful ) when doing this...
Hope this helps.
Sep 18, 2008 | Whirlpool RBS275PD Electric Single Oven
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
