Question about Hobart Food Mixers
I just got a used Hobart and it shuts down after a minute
    Top Expert:
  • Hobart Master
  • 78,335 Answers
Maybe the motor is defective.
Posted on Dec 09, 2016
My Hobart D-300 keep stop after running about 10 minutes and stay idol about 5 minutes then I can push start button to run another 10 minutes, it seam like control unit stop after it getting over heat and...
If your mixer's motor was built by Hobart; there are thermsiters built in to the stator's windings that can cause this problem. Check the amp draw while it is running. Also if your are over loading the mixer or using the wrong speed,, that will cause an over heating problem. You should be able to get on the ITW Food Equipment Group / Hobart web site(s) and get capacity chart.
Mar 01, 2015 | Hobart Food Mixers
Hobart h600 shuts off after running for a minute and then thermal resets
Check and see if your Vents are Open, you are overheating it and shutting down to protect your machine,. If it is not overheating then your Sensor is going bad. Clean it up and there is a better than average chance it will work much better...
Apr 09, 2013 | Hobart H600 Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Timmer assembly
this a 115 volt single phase timer you can buy the timer at hobart.com or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
55 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
