SOURCE: Remove block from phone
Hi, I am happy to serve you with this. I have sprint myself. Before you make a call dial *82, area code, and the humber. This will make your number visible. Example:
718-599-5555 you would dial *8217185995555
Go ahead and try. Also ask sprint that you don't need a private number. It seems like they categorized your number as private.
When you do want you number to be private, you dial with *67. The same way as above. This dialing rule applies to phone lines as well.
Take Care.
Artgirlny
SOURCE: Block calls from unidentified callers
this would be done if you put a request to your service provider.
SOURCE: All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
SOURCE: How can I block a number on my phone?
there is no otherway to block a specific number on phone...if u try or go for the call barring option this will blcok or stop ur all incoming calls....this facility (blocking a number) only provide by ur service providers like O2, etc.
SOURCE: My outgoing calls are showing up private, blocked
call your service provider and see if there is a caller id block on your account if not they will walk you through your phone settings to correct it
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
