Channel auto scan repeated 3 times with no success.
We have a prompt on our TV screen that says please run channel auto scan. We have run it 3 times, but the same prompt keeps re-appearing, telling us to do it again. Called Dish and they tried to help, but finally referred us to you.
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Dec 09, 2016
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
Please run channel auto scan
Auto channel scan is part of the initial set up procedure. Return to that procedure and repeat auto channel scan.
Jul 29, 2014 | Dynex DX-L19-10A LCD TV
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
