Question about HP Pavilion F1703 17" LCD Monitor
Same problem what are the solutions? the screen blue power button is on but the screen goes blank after 3 seconds.
  • HP Master
  • 1,684 Answers
The problem that we have found on that model is bad solder joints on the power board. Th board has coils called inductors that carry a good deal of current. The solder connections melt and the circuit breaks. You should be able to remove the back of the monitor and you will see one or more solder joints that are not making connection. heat up a soldering iron and apply a little bit of new solder to the connection. Re-assemble the monitor and you should be back working.
I hope this helps, If so please rate my solution.
Check out our web site for other monitor and printer repair tips. www.ccl-la.com
Buddy
Corporate Computer
Posted on Jul 20, 2009
Display is Blank
Step 1:
Press the Blue key/button.
Step 2:
Press the "Settings" button.
Step 3:
Press the "Screen Saver" button.
Step 4:
Adjust your screen saver time. Not sure if this is the problem you are having but give it a try. Please add more info about your problem to get more help. Good Luck.
Mar 18, 2013 | Mitel 5330 IP Phone
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
The PS3 will not play via hdmi. I start it on the cables go to display settings and slect hdmi the screen goes blank for awhile and then goes back to av
Instead please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Jun 21, 2010 | Sony Playstation 3 (PS3) Console
Blank screen, triple beeps when trying to shut off
I have looked around for you and here's what i found:
Try holding down the power button on the front of the unit till you hear a beep (4-5 seconds). If you don't the unit will power on, but won't reset the video settings. Most people don't hold the button down long enough.
i hope i have helped and i hope it works,let me know how goes !!
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
HP Pavilion Dv6000 with Vista screen goes blank
Sounds like a software issue with the power settings for the screen. Go into the display properties, open the tab that reads screen saver, click on the power button. Adjust the screen setting to never. This should take care of your problem, if it doesn't then it may be a loose connection on or around the screen. CHeck the connections.
Jun 19, 2008 | Computers & Internet
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
HP Pavilion F1703 17" LCD Monitor Logo
241 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
