Question about Video Game Consoles & Games
I recently got Broken Shield 1.I was called away and was not able to review the "saving" procedure. When I turn the game on now, it does not renew the explanation. How do I do that?
How to unlock smart watch forgot password
the Sally ProCard. Renewing Serum CE Their Sally Beauty Club as well as the Sally ProCard makes the member capable of taking advantage more savings on each item in the store. Additional benefits with greeting card membership is extra coupons, Beauty tips, newsletters, and latest product information.
http://ecoflexsite.com/renewing-serum-ce/ Renewing Serum CE Review Pursuit OF Youthfulness
Feb 23, 2016 | Cell Phones
Ps3 loads most games first time however after about 20 mins of playing battlefield BC 2 the sound stops working i can hear people talk through headset but no game sounds when i reset and insert the game...
Hi Danny41,
The disc reading problem is quite a common one!
It is caused by the laser coming away from the drive and you need to readjust the laser to get it to work.
Sounds bad but at least the drive is not broken JUST the laser needs readjusting.
Now let us look at how you can fix this:
Solution 1:
The normal way to fix this is to send it in and they will do the work for you at the factory. However it will cost about $150 and also you will have to wait about 4 weeks.
If you do not play on your PS3 that much this may be the best solution for you.
Solution 2: For A Faster Fix
If you want the games reading problem fixed quickly then you should check out some good PS3 Repair guides.
They normally include videos showing you how to readjust the laser - it takes about 20 mins.
Make sure you check out the full reviews below so you can fix a good one!
Click Here For A Full Review Of The Best PS3 Disc Reading Fix
Hope this helps and if so please leave a comment or if you have any questions let me know?
Apr 27, 2011 | Sony Playstation 3 (PS3) Console
Cancel automaticxbox live renewal
To turn off automatic renewal you have to call Microsoft support. 1-800-4MY-XBOX or 1-800-469-9269
Apr 25, 2011 | Video Game Consoles & Games
Black Ops has recently started freezing up towards the end of loading. Very few minor scratches and clean. All other games still load and play.
Hi plummerland,
Solution 1:
Mar 31, 2011 | Sony Playstation 3 (PS3) Console
How do you delete missed call message from vtech 6.0 phone
Open the caller ID screen and scroll through the recent calls. Hope this helps =]
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Ps3 keeps freezing on me.
This is usually caused by two major conditions.
The first condition being that if the Hard disk is really loaded with data and they are occupying a really large amount of the total disk space. This makes the console to have some kind of extra work to do while loading all the data which you have loaded onto it.
The second most known cause for this issue is as a result of errors in the hard disk or system. It makes it difficult for the system to operate as it should do normally.
Whatever the case may be, you can solve it by doing a hard reset on the PS3 console.
Below is the instruction on how to do a hard reset.
2220976.gif i.ad?site=techrecipes&adspace=ros&size=728x90&requestid=701187742 entertainment;kw=;ppos=atf;tile=1;sz=728x90;ord=123456789? leanandgreen;sz=1x1;ord=123456789? 2220796.gif i.ad?site=techrecipes&adspace=ros&size=160x600&requestid=114756662 entertainment;kw=;ppos=btf;tile=3;sz=120x600,160x600;ord=123456789? PS3 - How to do a factory / hard reset user-icon.jpg Contributed by seamonkey420 date-icon.jpg April 9, 2007
tag-icon.jpg Tagged: Games
entertainment;kw=;ppos=atf;tile=2;sz=728x90;ord=123456789? Well, i had some major problems w/my PS3 recently locking up and not playing any games/movies. After calling Customer Support, they suggested that i do a hard reset. This did seem to solve my problems, so here is the procedure per Sony CS. I would consider this a last resort troubleshooting procedure.
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 07, 2011 | Video Game Consoles & Games
How do i turn off automatic renewal for xbox live membership from my cridet card i for get the stupid pass word
call microsoft at 1-800-4my-xbox and tell the auto talk billing after that tell them your gamertag and you want to stop auto renewal
Dec 05, 2010 | Video Game Consoles & Games
Please step off press A - constantly repeated - why???????????
If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
assistance.
A. Check the batteries.
B. Check to be sure there is nothing pressing against the bottom.
C. If you are using it on soft carpet, put the foot extensions on.
1. The Wii Balance Board does not respond.
• Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
pressed. (The Power Button faces away from the TV.)
• Make sure the board has been placed correctly (see page 6).
• Make sure the batteries have been inserted correctly and are not been depleted.
• Make sure the game you are playing is compatible with the Wii Balance Board.
• Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
This procedure must be done for each Wii Balance Board compatible game.
• If, after verifying the steps above, the Wii Balance Board does not work, try the following:
1. Turn off the power of the Wii console with the POWER Button on the front of the console.
2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
3. Turn on the power of the Wii console.
4. Repeat the steps in this Operations Manual for setting up the board.
If the Wii Balance Board still does not work, follow the information at the bottom of this page.
2. Control of the Wii Balance Board is inconsistent or seems incorrect.
• Review the Instruction booklet for the game you are playing to make sure you are performing the
correct actions for that game.
• Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
• Make sure there are no people or other objects between you and the Sensor Bar.
• Avoid interference from other devices. If communication seems to be affected by other devices
(wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
or turn off the interfering device.
If the Wii Balance Board still does not work, follow the information below.
If the Wii Balance Board still does not work, an operational check procedure is available
in the Options Menu of the game you are playing. See the Instruction booklet included
with the Game Disc for more information. If your Wii Balance Board does not operate
correctly after all of the above steps, visit support.nintendo.com for assistance and
additional troubleshooting and repair options or call 1-800-255-3700.
Jul 19, 2009 | Nintendo Wii Fit for Wii
Xbox360 memory dump
call 1-800-4myxbox and tell them they will make you do some things that lets them view your memory code they will delete corrupted files.
Feb 11, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
