Question about Samsung Washing Machines
SAMSUNG WASHING MACHINE SW50ASP
Getting access to the under side of the control panel. Error code 2 being displayed
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
  • 3 Answers
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
Posted on Jun 17, 2008
rickzilla
  • 706 Answers
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Posted on Aug 17, 2008
  • 298 Answers
SOURCE: Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Posted on Mar 27, 2009
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/H error code on display?
This error is shown on the display due to:--
Water not getting detected while entering the washing machine or
The other possibility is that the Pressure switch is got tripped but its not getting detected.
This happens because in 30 seconds if the control does not detect water entering to the washing machine then the valves will be turned off and the error code will be shown on the display panel.
To solve this problem you will have to check the drain pump.is it properly fitted or got loose or worn out or leaking. Also check the pressure switch hose is in good condition and properly connected to Tub and Pressure switch.
This will help.Good Luck.
on Mar 11, 2010 | Washing Machines
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
    Hello.
    Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
    Blocked Pump
    One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
    Drain Hose
    If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
    Oversudsing
    If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
    Pressure Switch or Control Boar
    The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
    Thanks.
    Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
    We keep getting an f24 error. It won't spin out
    This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
    "F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
    To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
    Temperature Meter Reading
    32°F (0°C) 35.9 K ohms
    86°F (30°C) 9.7 K ohms
    104°F (40°C) 6.6 K ohms
    122°F (50°C) 4.6 K ohms
    140°F (60°C) 3.2 K ohms
    158°F (70°C) 2.3 K ohms
    203°F (95°C) 1 K ohms
    Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
    Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.****
    May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    DE Error in samsung washer SW50ASP What is it and how do i fix?
    De error refers to "Door Error".
    You do not need to buy a new machine. You can fix this.
    Look at the below mentioned link
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
    No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
    Thanks for using Fixya.
    Apr 28, 2009 | Samsung Washing Machines
    Maytag neptune mah5500b washer will not go into final spin
    most likely a code is stored in the computer as it probably encountered an error getting up to speed. this would probably be in the motor control board on bottom not the main control on top. main control will have the error though. tech sheet should be located in base of machine on side wall remove rear panel and look to left. this will tell how to access diagnostic mode and retrieve code.
    Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    42 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
