Question about Vacuums
Help I replaced my brush bar switch and it still won't stay on when vacuuming. I also can't figure out where this pieces goes back in
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
ukvacfan
  • 328 Answers
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Posted on Apr 02, 2009
ukvacfan
  • 328 Answers
SOURCE: Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Posted on Apr 05, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
How do i fix the brushbar on my vacuum cleaner there are three switches - power switch , brushbar switch ,and reset switch ,the latter does'nt seem to click ,should i replace this one
make sure you're getting power to the brush bar switch. If so there is a micro switch that activates the brush bar when you pull the handle back into the vacuuming position. Make sure that micro switch (in the ball assembly) is getting power from the brush bar switch.
Apr 08, 2015 | Dyson DC25 Animal Upright Ball Bagless...
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Vacuum won't stay powered without holding the button down.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Jan 26, 2013 | Dyson Vacuums
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Mar 05, 2009 | Kenmore 22313 Bagged Canister Vacuum
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Apr 29, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
