Computers & Internet Logo
S
Shannon Martindale Posted on Dec 08, 2016
I have run the channel auto scan as prompted, 3 times. It continually pops the same prompt up again.
Channel auto scan repeated 3 times with no success.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
How do I run a channel scan on new tv
Once hooked up go into the menu under set up. You will have to choose between air/antenna or cable. Select your choice and then it will prompt you to do a channel scan automatically or manually. Select automatic. If you are doing this as an antenna it should prompt you as to whether you want to scan for digital, analog or both. Select both.
2answers
Auto scan not working??
Make, model, and year please.
My screen keeps telling me to auto scan channels?
This is for basic cable TV. If you have basic cable, go ahead and let it scan channels. If you have digital cable or anything else and use a INPUT or HDMI or RCA to watch TV then just ignore the scan channels prompt as you have a cable box that handles all that for you.
How to install swat 4
Follow these instruction that will be help you -
1. Insert CD 1 into your CD/DVD drive.
  • 2. Wait for the auto-start feature to bring up the installation menu. Once the menu pops up, click on the "Install" option.
  • 3. Enter the serial number included with the game when prompted to do so.
  • 4. Place CD 2 in the drive when you are prompted to do so by the installation program, then click "Continue."
  • 5. Once installation is complete, you might be prompted to install DirectX 9.0c. If prompted, follow the installation procedure listed in the window.
  • 1helpful
    Wireless connection very slow
    Lets fix that
    How To See Current Auto Tuning Settings
    1. Open a
    elevated command prompt.
    2. Click on Continue in the UAC prompt.
    3. In the command prompt, type in bold belowand press Enter. (See screenshot below)
    netsh interface tcp show global
    4. Close the command prompt when done.
    5. Run through the steps below to see if you have a TCP/IP Auto Tuning issue
    STEP ONE
    How to Restrict Auto Tuning
    1. Open a
    3. To Restrict Auto Tuning
    NOTE: Allows for the receive window to grow beyond the default value of 65,535 bytes, but limits such growth in some scenarios.
    A) In command prompt, type in bold below and press Enter. (See screenshot below)
    netsh interface tcp set global autotuninglevel=restricted
    B) You will get a OK response if successful. If not, repeat step 3A.
    C) Go to step 5.
    4. To Highly Restrict Auto Tuning
    NOTE: Allows for the receive window to grow beyond the default value of 65,535 bytes, but doing so very conservatively. In this mode, Vista will by default use a RWIN of 16,384 bytes with a scale factor of 2.
    A) In the command prompt, type in bold below and press Enter. (See screenshot below)
    netsh interface tcp set global autotuninglevel=high
    B) You will get a OK response if successful. If not, repeat step 4A.
    5. Close the command prompt window and restart the computer to apply the changes.
    6. If it fixed your problem stop here. If not, continue to Step Two below.
    STEP TWO
    How to Disable Auto Tuning
    NOTE: Disables the autotunning feature in Vista completely, and sets and locks the RWIN receive window to the default value as 65536 bytes.
    1. Open a
    netsh interface tcp set global autotuninglevel=disabled
    image4.gifNote
    You can also type in bold below and press enter after each command:
    netsh
    interface
    tcp
    set heuristics disabled
    exit
    4. You will get a OK response. If not, repeat step 3.
    5. Close the command prompt and restart the computer to apply the changes.
    6. If it fixed your problem stop here. If not, you may not have a issue with Auto Tuning and will need to turn it back on. Continue to Step 3 below.
    STEP THREE
    How to Enable Auto Tuning Back to Normal Default
    NOTE: This turns Auto Tuning back to the default on (Normal) setting in Vista. Allows for the receive window to grow to accommodate almost all scenarios. See NOTE at the top of the tutorial for more on this.
    1. Open a
    3. In the command prompt, type in bold below and press Enter. (See screenshot below)
    netsh interface tcp set global autotuninglevel=normal
    image4.gifNote
    netsh
    interface
    tcp
    set heuristics enabled
    exit
    4. You will get a OK response if successful. If not, repeat step 3.
    That's it,
    Hit me back for more tweaks
    I have the box installed and on. Now what do I do to get the local stations on my TV
    What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use antennaweb.org or tvfool.com to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. tvfool.com will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
    If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
    Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
    I hope this helps.
    2helpful
    Pc won't boot ...
    it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
    When I tried to download javas new update it sent me a message saying windows installer is not opeating properly. I'm running Vista home basic. Can you help
    Try to ensure that Windows Installer service is running, or force start it. 1.. Open Run, and type in services.msc then press Enter. Alternatively, go
    to Control Panel -> Administrator Tools -> Services.
    2.. Locate Windows Installer in the all install services listing.
    3.. Verify that the Status is Started. If the Status column is blank,
    right click on Windows Installer and select Start.
    4.. If you get error trying to force start the Windows Installer service,
    try to change the Startup Type to Automatic (default is Manual), and then
    restart the computer.
    I would suggest you to run SFC scan which would scan for corrupt system files on the computer and replace them.
    Steps to perform SFC scan:
    1. Click the Start button
    2. From the Start Menu, Click All programs followed by Accessories
    3. In the Accessories menu, Right Click on the Command Prompt option
    4. From the drop down menu that appears, Click on the 'Run as administrator' option
    5. If you have the User Account Control (UAC) enabled you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
    6. In the Command Prompt window, type: sfc /scannow and then press Enter
    7. A message will appear stating that 'the system scan will begin'
    8. Be patient because the scan may take some time
    9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
    10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
    11. After the scan has completed, Close the command prompt window restart the computer and check.
    Grand Canyon Tech
    Grand Canyon Tech
