Voice recorder play back
Save & listen to recorded audio
I had the same issue and just connected the device to my computer USB connection and performed a quick format on the drive and it now works. You will be warned that reformatting the drive will erase all the data, which will happen. But you can simply reload your music and be back in business... Rod
Posted on Apr 19, 2008
SOURCE: RCA voice recorder problem
I let my rechargeable batteries run down before I closed a file. When I later transfered my file to the computer to the RCA Digital Manager program, I could do nothing and got the "Code Warning" message.
I left my DVR plugged into the USB cable and formatted my "removable drive G" which was my DVR. After that when I tried to turn on my DVR I got a blinking message "format." In desperation I pushed in the button for deleting a file from my DVR steadily for about five seconds. Voila! Everything came back to normal. I was able to turn my files into exe. files once again.
Posted on May 19, 2008
  • 8596 Answers
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
-Tha Mp3 Doctor
Posted on May 29, 2008
SOURCE: Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Posted on Dec 29, 2008
SOURCE: After i record my voice with the microphone, it comes out 1 side
The Samson C01U records in mono, not stereo. This is why you hear sound coming only out of one (the left) channel.
Posted on Apr 06, 2009
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
Hi i have a samsung B3210 and im having problems. i can hear the person on the other side but they can not hear me. How can i solve this problem
probably this is hardware problem.
to confirm it go to audio recorder and try to record your voice.
after recording save it and play.
if you listen clean and clear voice then it is not hardware problem.
if it's not hardware problem then try switching off or formatting your phone.
to solve hardware problem go to mobile repairing shop and ask them to fix new mike
Feb 10, 2011 | Samsung B3210 Cell Phone
I have an option on my sandisk sansa fuze mp3 player for voice recordings. There is pre-recorded literature that I would like to download, but, I only know how to download these voice recordings under...
You can't. Audiobooks are just like music, and the Sansa treats them that way. Think of them as words spoken without music.
Voice recordings are made on the Sansa, when you use it as a digital recorder. You can record lectures, meetings, or notes to yourself, and play them back.
Aug 10, 2010 | SanDisk Sansa e260 MP3 Player
RCA Voice Recorder VR5231-A audio files doesn't play in my PC
Save first your audio file to wav file format, then open it using Windows Media Player...
May 06, 2010 | RCA RP5016 Digital Voice Recorder
Not playing full recording
Maybe it's the preview play option of the player that you are using. It only plays a part of the recording for you to identify if it is the right recording that you are trying to find because the recorded allows you to record more than one file.
Sep 30, 2008 | RCA RP5010 Digital Voice Recorder
Play back up loaded files
if the name has been changed the recorder may not recognize it
Jul 11, 2008 | Olympus DS-2300 Digital Voice Recorder
WS-300M Olympus Voice Recorder
you can rewind a tad and listen, but you can't overrecord, because a digital recorder writes audio information into a data file and saves it. you just can play it back again and record a new file. if you want to cut off a part of your recording, you have to edit the file in an audio editor. - as the olympus stores wma-files, you'll have to convert them into wav format first to edit them. i tried the 'switch' software successfully.
Aug 13, 2007 | Olympus WS-300M Digital Voice Recorder
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
26 people viewed this question
