Question about Panasonic Vacuums
How to change on/off switch in Panasonic vacuum MC-UL915.
Kimi
  • 277 Answers
SOURCE: lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Posted on Sep 14, 2005
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Posted on Feb 23, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
Vac Belts
  • 701 Answers
SOURCE: Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Posted on Dec 20, 2009
  • 413 Answers
SOURCE: need owner's manual for Panasonic MC-9420 canister
goto> http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Vacuum-Cleaners/Canister-Vacuums/model.MC-3920
Posted on Feb 21, 2010
Testimonial: "Thank you for your fast, accurate response! Excellent service! Bill Bateman Midland, Texas"
Panasonic Vacuum MC-V7395 to replace the foot release pedal do I have to remove the belt and other things to get to it?
On most of the uprights I have worked on, the top cover has to be removed to get access to the release mechanism at the rear.
Apr 26, 2016 | Panasonic MC-V7395 Vacuum
How to change the belt
usually reading the directions helps .
Jul 27, 2015 | Kenmore 6 Canister Type C Sears Vacuum...
How do I change cable on Panasonic vacuum MC-E3003?
I wasn't able to find any answers/directions, but I did find the schematics on a parts website. Hopefully this might help you.
25398048-lp0tniytl1tz05r5qe5dhgvc-5-1.jpg You should be able to save the picture to your computer and then blow it up to see it better. I found it at the link below. You can try viewing it bigger there:
Panasonic MC E3003 Vacuum Cleaner Floorcare Parts
Feb 03, 2015 | Panasonic Vacuums
Brush won't turn on my Panasonic MC-CB467
There should be a safety reset button. So like if you suck up a rug it will shut the power to the brush roll off, then reset it.
Nov 14, 2012 | Panasonic MC-CG467 Bagged Canister Vacuum
Dec 20, 2009 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Lights are on but motor won't run?
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Vacuums Logo
101 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
