Question about Refrigerators
Water filter for icemaker location - Refrigerators
I have GE side x side cannot get ice to make or water thru the door I have changed ice maker and water valve also have made sure I have water to refrigerator and no frozen lines so don't know
if this box is a 2001 or newer it has a filter in water line. if this is it take filter and bypass that whole filter. also these boxs have main control located back of box and all fuctions go thru this board. If older than 2001 check icemaker were plugs in. You can force ejectors to make the ice maker run. cycle icemaker check for power at water valve. The ice maker valve is the small line
Sep 19, 2014 | Refrigerators
Samsung RF263 icemaker not filling with water
the fridge has an electric solenoid valve to let water in (just like your clothes washer) it is located where the water line goes into your fridge at the bottom in the back find,check, clean or, replace it.
Dec 03, 2013 | Samsung Refrigerators
I own a fridgidaire side by side. the model number is FRS26W2AW9. WE CAN NOT FIND WHERE THE WATER FILTER IS ON THIS UNIT. DO YOU KNOW.
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Sep 04, 2011 | Refrigerators
My refrigerator doesnt make any ice anymore?
look in your manual for the location of the water filter.
buy a new filter. if it has no filter , the only other problem is the water line is dirty and water cannot get to the icemaker. if the machine has water at the dispenser and you still have no ice , then your icemaker has a problem
Jul 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker is probably NOT run through the water filter. Typically the filter is only for the water through the door. Either the water solenoid valve that supplies water to the icemaker is bad or the icemaker is bad.
Mar 03, 2010 | Maytag MFD2561HE Bottom Freezer French...
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
There is water to icemaker but it does not make ice.
Check if the icemaker inlet valve is opening and if the icemaker solenoid is working.
If the icemaker has a filter also replace the filter.
May 22, 2009 | Refrigerators
Fishy smell in frig
Change the filter. Depending on your water supply and where you are located, you will get a buildup of junk that smells like fish.
It should be changed about every 6 months.
Feb 17, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Water and Icemaker do not work
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
