Question about Frigidaire Dryers
I have a frigidaire GLEQ332CAS2 dyer and my start switch (part# 134398300) fell apart (the insides of the switch came out) i was wondering if anyone knew how it went back together, i really don't wanna have to buy a new one but if no one knows how then i guess i am going to have to. any help would be appreciated
Illeagle
  • 525 Answers
SOURCE: Maytag Atlantis Electric Dyer wont start - I think is the thermal fuse
www.repairclinic.com
It should come with instructions in the package.
Posted on Jun 02, 2008
proton77
  • 1183 Answers
SOURCE: Dryer rattle
I guess you have stumbled upon the resolution yourself.
The Tub ratlling could be because of three things.
1. The Belt itself , as it might have slacked after use. and needs replacement
2. The tumbler bearing, that would require you to open the tub
3. The holding bolts that connect both the inside and outside tubs of the dryer.
and do check the floor balance of the dryer.if the surface is not even the dryer can tumble and make noise.
Thanks
Mandeep
Posted on Jun 03, 2008
rickzilla
  • 706 Answers
SOURCE: TRYING TO PUT DYER BACK TOGETHER
Please provide the specific model number so I can help you...
Posted on Nov 24, 2008
TheMobilian
  • 8220 Answers
SOURCE: Gas dyer won't start, have to kick start it.
If your bearing,glides, and idler are all fine then your motor is gone.
You could apply some zoomoil to that motor but you will have to drill some access holes as the manufacturer does not provide any. For $150 bucks a pop I would try a $2 bottle of High temp zoomoil from ace hardware first.Use a 1/6th inch drill bit and do not hit the shaft. The bearing wells are on either side of the motor and you will have to take the drum out to get to the motor. To access the dryer innards open the door and remove the screws holding down the top. Get the top out yer way and remove the front. Get the drum out and clean out the dryer. Send me any folding money you find. LOL You may find enough change in the dryer to buy some oil. Zoomoil is use for HVAC. It is heat resistant and does not disapate. After filling each bearing work the motor by hand till it loosens up. Oil the idler check the slides and the rear bearing for wear.743d531.jpg
Posted on Mar 10, 2009
Maytag317
  • 1136 Answers
SOURCE: Door switch isn't working
Hi, Is the switch a two or three wire?
Please let me know so I can try and assist you.
Thanks
Vic
Posted on May 25, 2009
The knob you use to turn the dryer on has broke off
have you been able to turn it with some pliers try it and then just get a replacement of ebay
Oct 25, 2009 | Frigidaire GLER341A Electric Dryer
TRY TO START DYER AND IT JUST HUMS I HAVE A FRIGADARE ELEC FRONT LOADING DYER
The belt may have broken, otherwise you have to use a multimeter to troubleshoot the problem.
Aug 17, 2009 | Frigidaire Dryers
Transmission fell apart. Looking for blueprint to reassemble.
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Apr 13, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Gas will not fire
I will send you some repair manuals if you like. Sea Breeze seabreezehvac@yahoo.com
Apr 01, 2009 | Frigidaire Dryers
The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
Hazard button fell in dash
this is easy fist you need to take out the sid unit thats the info display where the clock is .slide a piece of coat hanger into the two holes until you carnt send them in anymore slightly spread them apart and the unit will slide out do the same process with the radio this can be a bit fiddly but it does come out. after that you can get your hand inside and retrieve hazard warning light
Oct 17, 2008 | 1997 Saab 900
Dryer will not start
Hello jslovik,
Welcome
You said, When you turn the knob a buzzing sound starts but that's it. The Buzzing continues as long as the start button is turned. Dryer is only 2 years old. Any help is very appreciated.
It sounds like the starting switch is bad!
10 134398300 Switch,start ,turn type In-Stock $ 11.29It appears in the diagram at the page below in diagram # 10
http://www.pcappliancerepair.com/model-display.php
If you do not know to diagnose this or repair it, please call an authorized tech.
Let me know what you do and how it goes for you?
Huuum
Believed I solved your question.Happy to have been of assistance.
Please remember to leave a rating.
Sep 19, 2008 | Frigidaire FGQ332ES Gas Dryer
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Dryers Logo
170 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
