Question about Garden
Is there a sheer pin for second stage for47"snow blower
3 Suggested Answers
  • 78 Answers
SOURCE: my poulan snow blower keeps breaking sheer pins in the wheels,
1)try replacing them with a heavy duty "roll-pin"
these are available from auto parts stores.
two types are available.
first is the "single-roll",second is the"multi-rolled"with many layers to it.
try both they're cheap.
2)try not hitting things with the blades
3)dont force the machine in heavy wet ,or frozen icy packed snow.
Posted on Dec 23, 2008
  • 144 Answers
SOURCE: The auger on my snow
Hi, I will try to help you with a few suggestions that could be the problem. I have found that sometimes the shear pins break, but the ends of the pin do not fall out. Have you tried to remove them by hammering them off? Another possibility, if that is not the problem, then the auger gearbox might have a damaged gear or maybe just a broken or loose bolt or pin. If that is the problem then you need to take it apart. If that is not the problem you can check the lube level by removing the plug on the outside of the gear box and check for lubrication. Whatever type of lube that machine uses should be even with the bottom of the plug hole. If it is low or there is none at all add what is recommended in your owners manual. That is just preventive maintenance. But I think it might be just the ends of the pins not having fallen out. If that is the problem then you will need a punch to remove the center of the pin that is on the auger shaft. Hope this is helpful a bit, at least it is something to check out. Best regards and good luck.
Posted on Feb 03, 2011
WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE SNOW BLOWER VS A DUAL OR MULTI STAGE SNOW THROWER
Single stage has one rotating blade that collects and exhausts via upper shoot.
26373343-4yt0j151ox44pteg2g1nkeph-2-0.jpg Two stage has one blade for gathering into the center and a second that exhausts via shoot.
The two stage works best!!
26373343-4yt0j151ox44pteg2g1nkeph-2-5.jpg Hope this helps?
Nov 26, 2016 | Garden
I have a 22" craftsman snow blower walk behind. i managed to pick up a piece of wood while snow blowing. it sheered two bolts which i replaced. there is still a clunking in every revolution that i can
look at auger inside behind the pick up screw i bet it got bent from wood piece and is hitting side of housing
plus my son showed me a neet trick to use a timing light attached to plug wire and 12volt battery you turn the advance adj on light point light at suspected bearing or scuff point and you can see it plain as day (engine running of course ) use extreeme caution when doing this !!!!
Nov 30, 2014 | Craftsman Snow Blower 22 In. Dual-Stage...
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
Toro 828 oxe blower shear pin
knock the broken one out with a punch and hammer put a new sheer pin you can make on with a bolt just grind down the middle of the bolt so it is thinner than the rest , I do this all the time
Dec 12, 2013 | Toro Power Max 828 OXE Snow Blower - 28...
Snow blower auger stops in snow
There are cotter pins on the second stage blower shaft. I would inspect these. Also, check sheer pins in front auger assembly.
Dec 03, 2013 | Garden
Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Feb 10, 2013 | Craftsman Snow Blower / Snowblower Bottom...
What is a snow blower?
A snow blower gets rid of snow. There are one stage blowers (called snow throwers) that just throw the snow away. There are also two stage blowers that have one stage where the snow is put into the machine and then a second stage where the snow is blown away.
Jan 16, 2013 | Garden
I have 2005 Cub Cadet 528 SWE snow thrower and have trhe following problem. last week when clearing snow I ran over a wooden hockey stick and had to dislodge the broken pieces. Since then the thrower has...
http://www.manualslib.com/manual/34068/Cub-Cadet-Swe-528.html?page=20#manual
Check this page,
Two stage snow blowers all tend to have sheer pins
I would suspect that the holes seen in the picture are for the sheer pin, check with club cadet, figure same as auger pins, if so feel for the hole with your finger then inser a short nail till you feel a rough spot then tap with a hammer till it comes out, otherwise you have to take the mess apart completely.
Jan 02, 2013 | Garden
My poulan snow blower keeps breaking sheer pins in the wheels,
Dec 23, 2008 | Sport & Outdoor - Others
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
