Question about Garmin GPS
Garmin approach G5 switch has collapsed. Can it be repaired ?
    Top Expert:
  • Garmin Master
  • 79,186 Answers
Yes by Garmin, call them for an estimate, it will likely be about $125.00 USD
Posted on Dec 08, 2016
My sd card is missing on my Garmin Approach G5 Touchscreen Golf GPS. What do I do
You almost certainly do not need it. If your map list is not showing or if it locked try this:
Firstly, please connect your device to a computer. You will find a folder in the device called 'Garmin'. In this folder will be multiple files that start with the phrase 'gmap'.
Please delete the files starting with 'gmap'.
Once you have done this, please re-load the courses on your device using the Garmin CourseView updater which can be found here:
http://software.garmin.com/en-GB/courseview_updater.html
Oct 25, 2013 | Garmin Approach G5 Touchscreen Golf GPS
My brand new Garmin Approach G6 will not acquire a GPS signal. Is there some way to correct the problem?
All gps units need a clear view of the sky to collect enough data for a proper "fix". The less obstructions there are, the faster & more accurate the fix will be.
Initially, the first fix may take up to 20 minutes. Long acquisition times typically occur when the unit is powered up after being moved hundreds or miles or more since its last fix. This would be the case from manufacturing location in China where it was shut off to where ever you are now when you turned it on.
Acquisition times after this should be significantly less (10 - 60 seconds)
I hope this helps and good luck.
Jan 15, 2013 | Garmin Approach G5 Handheld GPS Receiver
Stuck in preview mode
If the back button does not work, power off the Approach.
Connect the Approach to your computer and try running the Garmin WebUpdater to load or reload the latest version of software. This will resolve most issues.
Power it back on and try doing a screen calibration by pressing the wrench in the bottom right corner and arrow down and press Calibrate Screen. Press on the dots using a stylus or the round part on the back of a plastic pen.
You may also want to contact Garmin Support for assistance. 1-800-800-1020
Dec 05, 2011 | Garmin Approach G5 Handheld GPS Receiver
MY GARMIN APPROACH G5 WILL NOT TURN ON
Check the batteries are fresh and installed correctly.
Connect the unit to your computer and run the Garmin WebUpdater.
download the latest version of WebUpdater software
If the unit is currently up to date, reinstalling the update again will sometimes fix any issues.
Sep 16, 2011 | Garmin Approach G5 Handheld GPS Receiver
When I press the side start button on my G5 Garmin GPS, only the word "GARMIN" appears and remains on the screen. Pressing the start button nor touching the screen will change anything. The...
reydriver,
The G5 user manual says in order to turn the unit off, press and hold the power button. Pretty common to Garmin GPS units. Have you tried that?
Jun 11, 2011 | Garmin Approach G5 Handheld GPS Receiver
Approach G5 screen say cannot unlock maps as soon as you turn it on. Suggestions?
There's information on how to unlock maps on Garmin nuvi satnavs at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. I don't know if the approach G5 would unlock in the same way but there's a good chance it would since they're both made by garmin. All I can say is have a look at the information on the link, check if the information you need is available on myGarmin and if the same files are on your GPS. If all these are the same it should work.
Apr 13, 2011 | Garmin Approach G5 Handheld GPS Receiver
I put new batteries in , pushed on button, Garmin screen comes on and that's it and then can't turn off. Need to pull the batteries to turn off. Any suggestions. This is on a Approach G5
This sounds like a firmware issue try downloading Garmins WebUpdater Software and giving the unit a firmware update. If your are unable to connect the GPS to the PC you will have to send it in for warranty or repair. Here is a link to the Garmin Software you will require for the updates.
Hope this helps!
Apr 06, 2011 | Garmin Approach G5 Handheld GPS Receiver
How do I reset the date and time on Garmin G5 Approach?
It will reset automatically when you get your first GPS signal, which is very cool. Mike
Nov 27, 2010 | Garmin Approach G5 Handheld GPS Receiver
GPS Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
