Question about OKI Office Equipment & Supplies
How to fix oki error code 134 - OKI Office Equipment & Supplies
    Top Expert:
  • OKI Master
  • 77,939 Answers
This machine will most probably require the main board as sometimes the heads can get knocked and temporarily disconnect. I have had this a few times and replaced many boards (the fuse blows that supplies the heads on the board).
Also, before replacing the board, the values of the faulty board will need to be pulled off with MUWIN and put onto the new board (meter readings and consumable usage).
Posted on Dec 08, 2016
How to fix okidata c 711 error code 134
Error code 134 on the OKI C711 refers to the white ribbon cable that plugs into the Black LED head. If it has come out of the head then check that the silver contacts are in good condition and none are touching each other. If any of them are touching each other then its a certainty that fuse F12 on the main board will have blown. If they are good then push it back in but this must only be done with the power off. I cant remember whether the 711 has a plug on the end of the cable or just has silver contacts. If F12 has blown then you cant replace it as its part of the board. Only a pcb repairer can change it or fitting a new board.
Dec 08, 2016 | OKI Office Equipment & Supplies
134 error
134 error is led head missing , the fault is either ( if your lucky) the k led ribbon cable has become unseated or the k ribbon pins are damaged (you can trim them with scissors.
Alternatively more often than not someone has nicked the led bar off and tried to put the cable back in without turning the printer off blowing the fuse on the maintenance board. The holders for that model are prone to cracking also.
Apr 10, 2014 | OKI Office Equipment & Supplies
Oki b431 service 134
It may be necessary to replace the LED head. Part number 44317201
Apr 03, 2014 | Oki Electric Industry B431dn Printer
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
MB 480 OKI Printer Error Codes
you can some error code at manual
if you did not have manual you can download amanual at
at that manual you can find some error code and how to fix it
Mar 12, 2011 | Oki Electric Industry Okidata MB 480 ...
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
Fatal error 134
flat barra led diconnect / barra led sporca
Nov 29, 2010 | OKI C5800Ldn Led Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
345 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
