Question about Crock Pots & Slow Cookers
Why is water/liquid escaping when nutri bullet on - lid seems tight
    Top Expert:
  • 78,257 Answers
There is no way to stop that vapor.
Posted on Dec 08, 2016
Oval lid, what is the correct fit, should it be a tight fit, or my just sits on top, there is a small space around.
You should have a fit that has a little wiggle room, including a little space around the edge of the lid. When you cook in a slow cooker, you'll make a bit of steam, and it needs room to escape. A super tight lid would likely end up 'burping', and possibly spraying spurts of whatever your sauce is, across your kitchen. Having that small groove there also leaves you a space where a bit of steam can condense and either trickle back into the pot to keep things moist, or just sit there in the gap and not drip all over your counter. Having a little bit of give also means that if you cook and let things cool, the condensing steam won't create a partial vacuum and leave you having to plant a foot on the side of the crock pot to pull the lid off (likely with more spectacular spew-age ready for viral videos).
Cheers!
Nov 06, 2015 | Crock Pots & Slow Cookers
Should the lid be a tight fit or loose
Most crock pots are made of porous ceramic and is relatively brittle. It is glazed on all sides (except the bottom usually), to make it hold liquids without absorption. The lids, usually glass or thermoplastic, sit of top, but do not usually fit tightly as this could crack the crock. Also, it is not a pressure cooker, so you want excess steam to vent. The lid just keeps the heat inside and allows condensation to drip back into the crock, reducing the speed at which the fluids cook off, thus the term slow cooker.
Nov 06, 2015 | Hamilton Beach Crock Pots & Slow Cookers
How do I remove a lid from a pot after it has been sealed by steam
What has likely happened is when the cooker heated up, the air expanded and escaped, when it cooled off, an air tight seal developed and the top acted as a valve and now the pressure is lower inside the cooker than outside. You need to break the vacuum... This may be done by gently prying the top a bit (carefully so as not to break it) or reheat the cooker. Is there liquid still inside? You could either turn it back on or possibly heat the entire cooker.
Dec 30, 2014 | Crock Pots & Slow Cookers
I have a Deni pressure cooker. 1 out of 10 times it works correctly. The last 2 times the top exploded off and spread liquid through the entire kitchen. Thank god nobody was injured. I have went through...
All pressure cookers should have a release valve. Be sure that is clean and allows a free flow of steam when the weight is not on it. Test it with just water in the pot. Heat the water until its just about to boil (with the lid off) then close and lock down the lid. Steam should start to come out of the release valve. If not .. clean it again.
Dec 11, 2014 | Deni Crock Pots & Slow Cookers
Lid doesn't fit tight
put aluminum foil around lid and press onto pot this will help it make tight fit
Jun 12, 2012 | West Bend 84496 6-Quart Slow Cooker
Do I use the rubber band whie cooking to hold the lid tight
No. Per manufacturer, steam needs to be allowed to escape.
Nov 07, 2011 | Hamilton Beach 33130TC Slow Cooker
Hi, The lid does not fit tight.I thought the lid
No it does not need to be tight, excess steam needs to escape.
Dec 20, 2010 | Rival 3355 5-Quart
I am cooking a roast and i just need to know how much water to put inside the cooker.
1/4 cup is enough. Roast has a high moisture content and will produce a lot of liquid for gravy! I'd only use more when I am cooking potatoes in the same roaster with the meat, then I would increase to a cup. Cover the roast tightly with foil or a good lid.
Apr 12, 2009 | Crock Pots & Slow Cookers
Why doesn't my cover fit tightly? 5.5 Qt Rival Crock Pot - lid does not fit tightly and hot water is bubbling and spitting out of the crock pot making a mess and an unsafe situtation...help! Is this a...
There's nothing you need to do differently except place the cooker where a little splashing won't hurt anything. This is typical of all crock pots. The cover fits loosely because it must allow steam to escape. When water turns to steam, it expands. If not allowed to escape, the steam pressure would explode the vessel. The simplest and cheapest way to let the steam escape is to let the lid lift freely. Some of the steam re-condenses into water as it escapes, and then it sputters and splashes as more steam comes out. They could make a more complex system to control the mess, but then a crock pot would be bigger, more expensive, and harder to wash. I know this might not be the answer you hoped for, but it's a truthful answer to your question so I hope you'll rate it accordingly.
Jul 16, 2008 | Crock Pots & Slow Cookers
Crock pot use
You should keep the lid on as much as possible. You are correct; once you open the lid, the liquid inside can quickly lose temperature at a rate of 10-15 degrees per minute.
Additionally, taking the top off allows steam to escape, which reduces the point of cooking in a slow cooker (cooking in a relatively closed system, with the steam condensing back to water and flowing back into the broth).
It's not doing a whole lot to the flavor (aside from causing the stew to thicken with the loss of water), but it is definitely causing the cooking to take longer than it should.
Nov 02, 2007 | Rival 38601 Smart Pot 6-Quart
Crock Pots & Slow Cookers Logo
91 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
