Question about Dishwashers
Bosche dishwasher Classixx E.09 fault code - what does this mean? Can I fix it myself or do I need an expert?
Machine is also not washing dishes that great and tablets still not dissolved in holder at end of cycle.
    Top Expert:
  • Dishwashers Master
  • 76,861 Answers
E:09 is a fault detected in the heating circuit. Try first tripping circuit breaker (or disconnecting power cord) for five minutes and see if this can clear the error.
If that does not work, call Bosch at the number listed on the dishwasher manual. The repair is not suitable for the home user.
About E:09 I quote the good clarificatory explanation given by
"E:09 relates to a fault in the heating circuit. This new range of bosch machines do not heat the water in the same way as the older range. There is no water pressure switch on the heater assembly as the circ pump contains the heater in one complete unit (heat-pump). The control module monitors the speed & current draw of the circ pump to ensure that there is water in the sump & it is also circulating. Your machine must be less than 2 years old, so should still be under warranty. Its not a DIY fix, it needs an engineer to sort it, as it is probably a fault with either the heat-pump or the control module."
Since I do not know your skill level I can't say if you can do this repair or not.
Posted on Dec 08, 2016
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
The heating cycle has changed and there is now a shorter cooler activity
the fan is probably busted. may just need to replace the fan. but if its washing the dishes fine and drying them , then you probably shouldnt worry too much about it.
Nov 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosche classixx 1000
Rotate the drum by hand. If the drum spins to freely without much resistance then it is possible that the drive belt has come off. Its unusual but it can happen. Remove back panel and refit the drive belt carefully.
If the machine is older than 5 years its possible that the wash motor brushes need replacing. If this is the case then you need to call a technician to replace them.
0417362396 Melbourne Metro area
Regards Sam
May 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Dishwasher not draining
Hi James:
What a coincidence. I am having same issue in my GE washer and I called a handyman. He came, checked through to make sure there is no blockages and concluded it is the pump. He said it is going to cost 350-400 and recommended I buy a new one instead.
Rav
Jan 21, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
Top Dishwashers Experts
