Question about Sewing Machines
I couldn't lift the lever of the pressure foot in novamatic. 2000 sewing machines
  • Sewing Machines Master
  • 646 Answers
Try to remove the latch on the foot. It sounds like the foot is nailed down with thread. You should be able to move the foot control up and down. You can remove the front of the machine and peak in at the foot lever to see if you see if there are any globs of thread.
Posted on Dec 10, 2016
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 202 Answers
SOURCE: presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Posted on Jan 08, 2009
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
How can i re attach the pressure foot to the lifting lever
From my 'playing with sewing machine' days, the nose of the machine swings open and reveals the lever, the sewing arm and the foot.
If that is not the case, you are going to have to use a screwdriver to get in there as there MUST be a way to get into it to clean and lubricate.
Dec 31, 2015 | Sewing Machines
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
I have the juki TL 98Q and the presser foot will not go up or down. The lever in the back moves but the foot stays up.
It could be as simple as the set screw in the lifting collar has came loose. If you open the end piece and raise the lever in the back up and down you should be able to see if the collar is loose. It will be on the pressure bar and it is the piece the lever pushes on to lift the foot. If just loose you have to put it to where it needs to be on pressure bar to lift it high enough and tighten the set screw.
Aug 31, 2013 | Juki TL-98Q
My singer 522 pressure foot lever has snapped! Can it be replaced?
I suggest taking the machine to a repair shop and ask them if
they can get the part
Nov 28, 2012 | Sewing Machines
My presser foot lever is not working on my toyota rs2000 sewing machine
How do you mean 'not working'? Is it not lifting the presser foot? Not putting it down? Fabric not feeding? There are several possible problems depending upon exactly how it is (mis) behaving.
Sep 07, 2012 | Toyota Sewing Machines
I have a pfaff hobbylock 796.
Has any little kids been around lately? Have they had access to your sewing area and machine? (thinking perhaps the pressure foot tension has been tightened down) If it has been tightened, losen it a couple turns, see if that helps (remember, left to loosen, right to tighten)
When is the last time you oiled this machine? Typically sergers require a clean and oil each time you go to use them. Locate the bar that correlates to the presser foot add a drop of oil to the bar and let it seep in. After a few minutes try lifting the presser foot.
Also does the presser foot lever move at all?
Aug 20, 2012 | PfaFF Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
When I raise the lever the presser foot only lifts a bit at the end of the motion and doesn't stay up. Is the foot supposed to remain up after the lever is raised? In the first 40 degrees of motion...
yes, pressure foot lever should stay raised, this sounds like the spring has broken in your machine. if you are comfortable with delving into the machine you could open it up and take a look. alternatively take it to a sewing repair man and get it serviced as well as clean and lube.
Jun 26, 2011 | Kenmore 15218 Mechanical Sewing Machine
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
The foot lever has gotten jamed and now i cant lift it or lower it. can the tension spring be the problem?
The tension has nothing to do with the foot lever.
However, the foot lever has an effect on the tension controller.
When the foot lever is up, the tension is open.
When the foot lever is down, the tension is closed.
If the lever will not release when you lift it as high as possible, you will need to take the machine in for service.
Mar 10, 2010 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
