How to find area of a triangle, - Office Equipment & Supplies
    Top Expert:
  • Office Equip... Master
  • 75,824 Answers
Posted on Dec 08, 2016
What is the answers for 6th grade HH.4
Area of a Triangle - Math Goodies
www.mathgoodies.com/lessons/vol1/area_triangle.html
  1. Cached
  2. Similar
To find the area of a triangle, multiply the base by the height, and then divide by 2. The division by 2 comes from the fact that a parallelogram can be divided into 2 triangles. For example, in the diagram to the left, the area of each triangle is equal to one-half the area of the parallelogram.
Work out the area of the green triangle, and subtract the area of the white triangle.
Google
Mar 30, 2017 | The Computers & Internet
The area of triangle LMN is 18 ft2 and the area of triangle FGH is 24 ft2. If , what is the ratio of LM to FG?
In two similar triangles, the ratio of their areas is the square of the ratio of their sides. Let's assume LMN and FGH are similar triangles. The ratio of the areas of LMN to FGH is 18 to 24, or 3 to 4 or 0.75. We would then take the square root of 0.75 to get the ratio of the sides. I get 0.866. The reason it is the square is the area of a triangle is base times height divided by 2, and the base and height and sides of similar triangles are proportional.
Good luck.
Paul
Similar Triangles ratio of areas
Mar 12, 2015 | Office Equipment & Supplies
THe area of a triangle is 80meter squared. If the base and height of the triangle are tripled, what will be the area of the new triangle?
720.
Here is how i did it (my way).
1. doubled the area to 160 and found two sides of a square that would equal the area (a*b). I chose the numbers 16 (which I will use for the base of my triangle and 10 for the height.
2. Checking my answer, (h*b)/2 I see that my triangle area is indeed 80
3. multiply the base *3 = 48 and height *3 = 30
4. (30*48) / 2=720
5. Work check using calculated area of a square 3x larger: (a*b)=area (48*30) = 1440 1/2 of the area creates a triangle so: (1440/2) = 720
This may not be common core or whatever is being taught now, but having a basic knowledge of geometry allows me to figure out problems like these pretty easily.
Mar 06, 2015 | Office Equipment & Supplies
Trying to solve the area of a triangle
The are of a triangle is 1/2 * the base * the height.
So if the triangle is 2 for the base and 4 for the height. it would be (2*4*1/2) or 2*4=8, 8*1/2=4. So the area of the triangle would be 4 square (until of measure).
Of course this assumes you know the base and the height of the particular triangle.
This site might be a bit more helpful for calculations where some of the numbers may not be known. Good luck!
http://www.wikihow.com/Calculate-the-Area-of-a-Triangle
Feb 04, 2015 | The Learning Company Achieve! Math &...
What is the pyramid total surface formula
A pyramid has 5 sides including the base. If the base is a rectangle L long and W wide, its area is L*W.
The other sides are triangles. If the height of the pyramid is H, the triangles that are L wide at the base will have a height of the square root of half of W squared plus H squared, or SQRT((.5*W)^2+H^2) and the two that are W wide at the base will have a height of SQRT((.5*L)^2+H^2). The area of a triangle is .5*height*base, so the total surface two triangles with the same height and base is 2*.5*height*base = height*base.
So, the total surface area of a pyramid L long by W wide by H tall would be:
L*W (the area of the base)
+ L*SQRT((.5*W)^2+H^2) (the area of the 2 triangles with base L)
+ W*SQRT((.5*L)^2+H^2) (the area of the 2 triangles with base W)
Hope this is helpful!
May 23, 2014 | Encore Math Advantage Algebra II and...
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Mar 29, 2014 | Office Equipment & Supplies
What is the effect on the area of a triangle if the base is doubled and the height is cut in half? What happens to the area, if the base is doubled and the height remains the same?
Use the formula for the area of the triangle with symbols.
Let b be the measure of the base, and h the measure of the height.
The area of the triangle is A= b*h/2 (original situation)
Now consider the new situation (situation2)
Let b` the new base and h`the new height.
We have b'=2b, and h`=h/2
The new area A`=b`*h`/2=(2b)*(h/2)/2=b*h/2 and that is equal to the original situation.
Now consider a third situation
Let b"=2b, h"=h
A"=b"*h"/2=(2b)*h/2=2(b*h/2)=2A
Mar 10, 2012 | Computers & Internet
Use the formula for the area of the triangle Area=b*h/2.
If the base becomes b'=2b and h'=h/2, then the area of this new triangle is Area'= (2b)*(h/2)/2.
As you can see the two 2's introduced cancel one another and the area is unchanged. A'=A.
If the base is doubled and the height remains the same, then b''=2b, and h''=h. Substitute in the area formula for a triangle to get
A''=b''*h''/2= (2b)*h/2= 2*(b*h/2)=2A
You see that in this case the area is doubled.
Jan 18, 2012 | Computers & Internet
What are the different formula in solving the area, height, base of a trapezoid?
o find the area of a triangle, multiply the base by the height, and then divide by 2. The division by 2 comes from the fact that aparallelogram can be divided into 2 triangles. For example, in the diagram to the left, the area of each triangle is equal to one-half the area of the parallelogram.
Since the area of a parallelogram is area_parallelogram_form.gif, the area of a triangle must be one-half the area of a parallelogram. Thus, the formula for the area of a triangle is: area_triangle1.gif or area_triangle2.gif where b.gif is the base, h.gif is the height and · means multiply. tab.gif The base and height of a triangle must be perpendicular to each other. In each of the examples below, the base is a side of the triangle. However, depending on the triangle, the height may or may not be a side of the triangle. For example, in the right triangle in Example 2, the height is a side of the triangle since it is perpendicular to the base. In the triangles in Examples 1 and 3, the lateral sides are not perpendicular to the base, so a dotted line is drawn to represent the height.
May 13, 2011 | Computers & Internet
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Calculated Industries Pocket Real Estate...
29 people viewed this question
k24674
