Question about Vacuums
Have 2 batteries. Neither one keeping a charge. Put in vacuum run for a few seconds then done. Put on charger then the blue light doesn't flash when the battery is in place.
    Top Expert:
  • Vacuums Master
  • 78,289 Answers
What can I say, you need a new battery. eBay is a good source at a reasonable price.
Posted on Dec 08, 2016
Dyson v6: It looks like it stopped charging.
If it's only 2 weeks old, you could have a defective either charging system or just a bad battery. Most places offer free replacement within 30 days of purchase. I would take it back to your place of original purchase. I hope that helps!
Mar 21, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
My dyson shuts off after just a few seconds of run time.
Make sure the charger is operating. Then if it is, look at a failed battery.
Jan 13, 2015 | Dyson DC16 Root 6 Bagless Handheld...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Just put a new battery in scuba and it runs about 30 seconds (completely charged)
1) replace again the batteries by new ones and completely charged.
2) test the charger if if functioning properly, can be faulty, and not charge well the batteries.
3) test the power supplies inside from the scuba, to due some short circuit drain the batteries.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
UNIT WILL ONLY RUN FOR FEW SECONDS THEN THE BOTTOM OF THE 3 LIGHTS WILL FLASH
I'm sorry to hear you're having difficulties with your DC16. A single flashing red light indicates that the battery needs to be recharged. When fully charged, all 3 LEDs should illuminate without flashing. However, if the red light continues to flash even after at least 3 hours recharging time, there may be a fault with the battery or charger assembly.
Please get in touch with us directly - one of our experts will be happy to run through some troubleshooting over the phone with you to determine whether the battery or the charger requires replacement. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
