Hello i have a washing machine schulthess spirit 5050 and in her display its an error F-10 what can i do ?
    Top Expert:
  • Washing Mach... Master
  • 78,267 Answers
You can try to unplug it first to see if it resets, if that fails you need to have a service done.
Posted on Dec 08, 2016
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/10 error code on...
The error F/10 is shown on the display due to Motor Control Unit (MCU) Heat Sink Thermal Trip detected in the washing machine.
In this problem check the thermal protector on the MCU heat sink .if the MCU seems hot then it’s the faulty part blocking the motor from running.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
How i can solved the error code cfb31 for km 5050
i have the problem cfb31 in machine kyocera km 4050/5050
Dec 23, 2014 | Kyocera Office Equipment & Supplies
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
How can i clear an error c3300?
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
Aug 25, 2012 | Kyocera KM 5050 Toner Cartridge 34000...
WHAT IS E0 ?
Hello there and welcome to fixya
The error code "OE" indicates a drain error. This error will display if the washer is draining too slow or if it's not fully drained in within 10 minutes. This would also explain why it's not spinning properly.
The drain pump filter will need to checked and cleaned
May 28, 2012 | Washing Machines
Whirlpool duet wfw9200sq02 f28 error code
What the F28 error code means is "serial communaction error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F28 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it advise, ya call for service so the operation of both control boards can be checked to see which on has failed.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Stops into wash displays f 10
F-10 Washing Machine Error Code
Motor control unit (MCU) heat sink failure error code. Thermal sink on MCU overheating.
- Ensure proper clearance around the washing machine.
- Visually inspect motor control board and central control board wire harness connections.
- Test wire harness to motor connection.
Hope this helps.
May 17, 2011 | Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
