Question about KitchenAid Food Mixers
Can I open my Cuisinart mixer and add lubricant? I have the lubricant that is used for Kitchenaid mixers and assume that can be used in the Cuisinart.
    Top Expert:
  • KitchenAid Master
  • 80,668 Answers
It uses a food approved oil.
Posted on Dec 08, 2016
How to add oil to cuisinart SM-55 stand mixer
The owners manual is available on the website. It doesn't mention anything about adding oil. What makes you think it needs oil. Mixer gears are usually lubricated with white grease and are maintenance free.
Nov 23, 2013 | Food Mixers
Trying to determine how to lubricate the gears?
Hi CONTACT_TOS. I’m not sure what removable cap you are referring to, unless you are referring to the two plastic caps with screwdriver indents on opposites sides of the head? Do not remove them. Those are Brush Holder Caps for access to the electric motor brushes. You do not want to remove them unless you are replacing the brushes.
Why do you want to add lubrication to your mixer? The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'. Unless your mixer is quite old; greater than 10 years, you shouldn’t have to replace any transmission lubricant. Your mixer’s transmission lubricant (grease) does break down over time and usage into its components; basically oil and suspension additives, and sometimes your mixer might leak a little oil that has seeped beyond the transmission gasket and found its way out of the mixer. Gravity can be very insidious. But even then, if the amount of oil you find leaking is small and your mixer seems to be operating normally, you needn’t worry about the replacing the lost lubricant.
If you still wish to check or replace the lubricant, that’s OK, too. It never hurts to get under the ‘hood’ of your mixer and see how it all works. Before you get started though, it would be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and select “Consumer” for User Type, then enter the 6 character Model Number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4). (Check to verify this matches your mixer model.)
Turn to pages 4 & 5 titled: “Case, Gearing & Planetary Unit,” for the disassembly, troubleshooting, and reassembly of your mixer’s transmission gears, along with all the parts. It can get quite messy but be gratifying to diagnose and repair your mixer yourself.
Once apart you can check for any unseemly wear and tear on the gears, etc. You may also want to consider replacing all the grease, particularly if debris is suspended in it.
Besides any replacement grease you might consider replacing the gasket (Illus. No. 26), too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer along with replacing the lubricant if you wish to.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. – hslincoln
May 04, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Leaking fluid, oil I think around the kitchen aid ring
Bucksmom, Sorry to hear you mixer is 'leaking'... I hate it when that happens. You don't mention how old or what model your KA mixer is? I assume you mean the band around your mixer with the Kitchenaid logo, when you say 'kitchen aid ring.
Your mixer does have an internal gear mechanism (transmission if you will) which converts the electric motors rotation into the mixer rotation and those gears are located within the mixer. The gears were lubricated at the factory, but depending on the age of your mixer and how it is used, it is possible that the grease has leaked beyond the gasket and that is what you are seeing now.
It is possible to disassemble the mixer to determine where the grease is coming from and troubleshoot if anything else might be wrong within the transmission.
Hopefully the leakage is not getting into your food being mixed. Kitchenaid Grease should be 'food grade' grease, but you still don't want to ingest it.
I hope this helps... Howard, Burke, VA
Nov 01, 2009 | KitchenAid Food Mixers
Brown oily substance is leaking out of the mixer
It's the gear lubricant. It's food grade so no panic of contaminated food required. When it is all done leaking you may need to buy a new mixer or order a repair kit and open it up before the gears get ruined. - good luck- Ned-
Aug 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid mixer makes a sound like it needs oil or lubrication. Please advise.
Kitchenaid mixers are overpacked with oil to last the lifetime of the mixer, and do not require lubrication unless you have lost in excess of .25 cups of oil.
Please post any tell-tale signs that are indicating to you that a replenishment of oil is needed.
Jul 04, 2009 | Food Mixers
Mixer gets hot and smokes when in use.
Smoking and overheating during use does not usually indicate a problem with motor oil. Kitchenaid stand mixers have sufficient oil in them to lubricate the motor for its lifetime.
Smoking and overheating are geneally caused by overuse. Consult your use and care guide or Kitchenaid Customer Service to ensure the mixer is being used properly. Customer Service would also be able to send you a new Use and Care Guide at no charge.
Their toll-free telephone number is 1-800-541-6390.
Apr 26, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Adding oil to the k45ss
Hi. Goto www.kitchenaid.com enter your model # into the search window, look for the parts catalog for your mixer. Download this file. It will come in handy if you ever need to order parts, and will give you an overview of your mixer.
Goto www.mendingshed.com and locate the free Kitchenaid Service manual. This manual contains all of the info needed to service your mixer.
Finally, your mixer uses grease for lubrication. When you see oil dripping, it means that your mixer needs to be re-greased as the oil is separating from the grease base. I recommend Chevron FM ALC EP-2, this is a food grade grease that is non-toxic should you get some of it's oil in the mixing bowl at a later date. Remove the old oil and grease remnants from the mixer, including the planetary unit. You can remove the planetary by tapping the tapered pin out of the shaft. Clean and re-grease. After you've completed these tasks, run the mixer for a couple of minutes every week to keep the oil in suspension. This will extend the life of the grease.
Good luck! If this solution has assisted you, please rate it. ricardok45.
Mar 29, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
Kitchenaid mixer leaking oil
Some of the oil has separated from the grease inside the transmission, the grease should be replaced. You don't need a total dismantle,. simply remove the top cover and the transmission housing. Remove as much old grease as you can, then replace it with grease from Kitchenaid Parts, or locate a Shell Oil distributor in your area, you want Shell Darina XL EP-2. The oil that came out of your unit probably won't be enough to do immediate damage, but because it's separating, it's becoming less effective. It'a messy job to remove it but will add years of life to your mixer. If you find this solution helpful, please rate it. Good luck. ricardok45
Sep 28, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
122 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
