Question about Kenmore Kitchen Ranges
Fan flew off How to fix?
Kenmore Elite stove fan it won't screw back onto stem How to get it back on and how to stay on
    Top Expert:
  • Kenmore Master
  • 77,499 Answers
You will need to replace the motor and the fan most likely.
Posted on Dec 08, 2016
Kenmore Elite Microwave Hood Combination fan blows air out of the top but is not sucking in the heat from anything on the stove...for example boiling water.
does th fan exhaust to the outside --filter clean --directional duct to out side --also small unit so will not suck air like a standard stand alone exhaust fan which are over 3 to 4x the size
Jul 31, 2016 | Kenmore Microwave Ovens
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
KENMORE REFRIGERATOR WON'T COOL ON BOTTOM BUT FREEZER WORKS BUT HAS ICE ON BACK WALL
needs fan replaced, there are a couple of plastic strips down the sides of the bottom plate, remove those to expose screws remove bottom pan then back wall fan will unclip from wires local appliance store should have one avaiable
Jul 04, 2012 | Kenmore Refrigerators
I have a Kenmore elite bottom freezer model. The fan started making a funny noise.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace the blade. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged and rubbing against it. Check the rear condenser fan as well for faults. It is possible that the noise is coming from the motor itself. If that is the case, you will need to replace the affected motor.
Aug 23, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator, very hot between doors
Mine was doing the same thing. I pulled the cardboard cover off the back near the bottom and found the fan was not turning and lots of dust buildup. I unplugged it and vacuumed it out and spun the fan by hand and plugged it back in. The fan started and the temp between doors went down. I may have to replace the fan soon.
Aug 22, 2009 | Kenmore Refrigerators
Burning plastic smell coming from new cooktop fan.
Sorry - this is not an answer but a question. Did you get your problem resolved. We just purchased a induction stove & oven and are having the same problem you described. Could you let me know what happened. Regards Bob
Apr 06, 2009 | Kenmore Elite 44173 30 in. Electric...
Kenmore elite ranghood (series# 550) not working
unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
Dec 07, 2008 | Kitchen Ranges
Kenmore elite he3 dryer
Some coins or other objects may have fallen down in to the blower housing. Unplug the dryer. The Front lower cover has 2 screws holding the outer panel on. There are several screws in the blower housing.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
