Question about Kenmore Refrigerators
The hood fan of the Kenmore elite came flying off not sure how to fix it
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Looking for manual on how
You can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Dec 18, 2008
  • 132 Answers
SOURCE: lights dont work but fan
the switch may be Faulty the fan and light are on parallel circuits.
Posted on Dec 26, 2010
My hood fan quit working on my kenmore microwave/ hood combo. How do I fix?
Check to see if fan is getting power. If it is and the fan does not turn then you need to replace that motor. Also check motor bearings - not uncommon for them to get all gunked up with yuck from the air they push through the hood.
Aug 23, 2017 | Kenmore Microwave Ovens
We just hooked up the hood fan and was wondering if it was normal that when you run the microwave the hood fan cuts in?
I do believe that is the normal way to get rid of the heat and any moisture while the micro is operating .
Aug 28, 2015 | Kenmore Elite Over The Range Microhood...
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite 36" downdraft dimensions
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Mar 11, 2009 | Kenmore 59940 Kitchen Hood
Instalation instructions for kenmore range hood model 50303
You should be able to find the manual here:
http://www.managemylife.com/mmh/owner_manuals/13409/KENMORE-ELITE-Range-Hood-L1004363?brand_name_search=kenmore+50303
The file name is L1004363.pdf
Jun 07, 2008 | Kenmore Italian Design 50303 Kitchen Hood
Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Apr 05, 2008 | Kitchen Ranges
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Refrigerators Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
