Question about Panasonic Televison & Video
I have a Panasonic TC-P50S1 with a March 2009 date and MA90790114 on the label. It does not come on. It has a 10 blink signal.
I pulled the back off of the TV to look around for blown fuses. I could not find any.
    Top Expert:
  • Panasonic Master
  • 75,591 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Posted on Dec 09, 2016
What does it mean if i get 6 blinks on my tc-p50s1
i guess it would be the PSU board,remove the back lid an check for any blown capacitor and replace it yourself - having an ESR meter will help to detect the other bad ones that will not last long
Jun 05, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Hello i have a panasonic TC-P50S1 plasma tv (2009) and it does not turn on properly anymore. You turn it on and then it turns off and start to blink repeatedly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 16, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
PANASONIC TC-P50S1 NOT POWER ON, 10 BLINKS
You need to either replace your PSB-power supply board with a refurbed one or replace the Blown capacitors on the PSB. Solder kit w/ flux from harbor freight or radio shack and about a dozen thru-hole caps about 2v above the current load rating on the blown caps. You can also just buy one from shopjimmy ebay or partsstore. You have to remove the back panel and remove the PSB. The board will be printed Power Supply and the REV number (part number) will be on it as well use that to replace. Disconnect the wire harness/ribbon cables and a few screws to pop the board out. take pics or number the wires/cables so you know where to plug them back in when either the repair or replacement is done.
Feb 08, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a panasonic viera TC-50S1 i turned it on yhe picture was messed up .. it shut off and will not turn back on the red light keeps blinking one time
Assuming you meant TC-P50S1, as TC-50S1 is not a valid model, 1 blink code means suspect bad A board (main board). Below is a link to the parts list for that TV model.
http://www.tristatemodule.com/t-Search.aspx?q=TC-P50S1
Nov 03, 2013 | Televison & Video
I have a two yr old panisonic TC-P50S1 that wont power up . You hear it click on then it shuts off ?
Hi no power and a clicking sound usually means that your power supply is bad. You will need to replace it.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
WHILE WATCHING MY TV TONIGHT I HEARD A LOUD POP AND NOW NO PICTURE JUST BLINKING RED LIGHT
10 blinks for this tv is not always an A Board issue. It can be a problem with the power board as well. A technician should look at the set to dertermine where the problem lies otherwise it is just a guessing game of inni minni miny moe.
Apr 03, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
