Question about Pasquini Livia 90 Espresso Machine
Where can i purchase a suppression valve for an older Livia 90 expresso machine? possibly need other parts as well
My unit is 1000 watts. definitely older ... serial # 068. it would not pull shots ... opened up and found cracked part on suppression body
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
Try eSpares some are alike in side may be its not worthy to fix
Posted on Dec 08, 2016
I have an older Pasquini Livia purchased in the early 90s. It continues to heat up and then the relief valve goes off. Is there a thermostat to replace?
Yes, remove the top panel on the right side is a p. stat with a microswitch on top, either that has to be replaced or the tube is blocked and it cannot read the steam pressure.
Nov 10, 2011 | Pasquini Livia 90 Espresso Machine
How to take the water reservoir out the livia 90 espresso machine
Hi
It should lift straight up. If it is one of the newer machine, it will lift right out. If it is an older machine it will have a wire attached to the left side of the tank. The wire will pull off at the terminal. Pull straight off at the same angle or you might damage the tank. Rember to reattach the wire when putting back in.
May 02, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Livia 90 Lights come on then off, hums but not pumping
It is possible that the pump is blocked or damaged, remove top and side panels and check lines going to and from pump, you can run the machine without the panels and you will be able to see if the water is moving to the pump or if the pump is vibrating.
Feb 22, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
43 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
De Brewerz
De Brewerz
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
