Question about Ariston Technologies Washing Machines
Ariston front loader washing machine is dumping out water everwhere, why?
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Posted on Jan 27, 2010
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
Washing machine won't take enough water and won't take washing powder and leaves bad smell inside
AH yes front loaders are bad about this type problem .change the detergent to liquid and run a coulpe empty wash cycles with bleach and or baking soda
Mar 21, 2015 | Ariston Technologies Washing Machines
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Fix front loader ariston av 61
your filter is blocked / pump is jammed.
if you need help. let me know
May 01, 2014 | Washing Machines
Probably blockage in either sump hose or pump
Jun 14, 2013 | Washing Machines
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
We have the Ariston Margherita front loader washing machine and cannot get the door open
Good luck
May 17, 2009 | Ariston Technologies Ariston AWD12 Front...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
35 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
