T8000c honeywell thermostat is blank but the furnace is still working fine, just blank on the thermostat screen.
    Top Expert:
  • Heating & Co... Master
  • 41,808 Answers
May need battery replacement
Posted on Dec 08, 2016
Is there a battery in the t8000c thermostat the screen is blank
There should be a couple of AAA batts in it. Grab all 4 corners and pull straight out & off the mounting plate. If no batteries are installed it is hard wired & the problem is at the air handler(blown blade fuse or open transformer winding). When you reinstall batteries make sure there is no corrosion. And careful when you put the tstat back onto the base. There are some small pins that need to align with its holes/terminals. Honeywell has a great 1-800 support #. Should be on the tstat.
Jun 28, 2015 | Honeywell TH8320U1008 VisionPRO 8000...
I HAVE A HONEYWELL MANUAL THERMOSTAT NO BATTERIES ALL IT HAS ON THE BACK IS T8400C 1099 (2) 0710 1B HELP, IT DOES NOT SHOW ANY THING THE SCREEN IS BLANK
This model of Honeywell thermostat uses the 24v from the unit to power it. One of three things must have happened.
1. You have lost power to the furnace, therefore no power to thermostat.
2. You only have 4 wires hooked up on the thermostat and not 5. A lot of older homes had just 4 wire running to the thermostat, which will not work for this thermostat. You should have a wire connected to the (C) or (B) terminal on the thermostat, which ever one they have, I can't remember off hand. These are the Common terminals. They have to have the common from the furnace 24v power to operate.
3. Faulty thermostat, which will obviously have to be replaced.
Hope this helps and gets you to cooler days!
Jun 28, 2012 | Honeywell Heating & Cooling
Honeywell t8000c display is blank, unit doesnt run
I would say that you have one of two issues. Either your thermostat is bad or you do not have 24v coming from the heating unit. In this case the problem would be in the low voltage circuit of the heater. At the heater you should have 24v AC when you place an electric meter across the R terminal and the C or W terminal. If you have no vaoltage across the R to either the C or W then you have a bad transformer or a blown fuse in the furnace. If you do have voltage ther and also at the t-stat then the t-stat has gone bad, replace it.
Nov 14, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
This unit doesn't require a battery. It runs off the 24v from the unit. Check that your transformer is still working. Check the control board for 24v pwr. and main pwr. Check your breaker to the unit. It could be as simple as a bad stat too. You can check by using a jumper wire and jumping across from r term. to y term.
Apr 10, 2009 | LG Art Cool LA121CNP wall/window Air...
Honeywell T8000C Thermostat Problem
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Sep 28, 2007 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
