Question about Ricoh Office Equipment & Supplies
Scantool only scanning about 1 inch of document. We have the rw240 ricoh
  • 82 Answers
SOURCE: how do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
Ajkill
  • 2035 Answers
SOURCE: Black line during scanning
Clean the scanner bed with the clean cloth and try to make a copy if it stills as a black line, if your printer is within one year warranty please get it replaced by the company and use this link:
http://support.lexmark.com/static/229-1-0-549.html
Posted on May 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
komguy
  • 2306 Answers
SOURCE: I have a canon dr-9080c scanner and it is having
Sounds like you need a new CIS unit, the scan assembly or its lamps are flickering.
Posted on Jul 28, 2009
  • 10 Answers
SOURCE: Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Posted on Jan 08, 2010
Rw240 plotbase 3.7.8
3.8 is the RATIO offered upgrade for Windows 7 install of PLOTBASE & SCANTOOL. Check for information on it on ratio.us website
Mar 06, 2014 | Ricoh - RW-240 Print Controller - 411737
How to scan from machine to PC
  • 1. Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • 2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • 3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • 4.Close the printer's document lid slowly so the document does not shift position.
  • 5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • 6. Push the scan button. You may have to do this on the printer itself or on your computer.
  • 7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • 8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
  • 9. Accept the scan and save. Return the original document to a safe location.
  • Aug 10, 2012 | Ricoh Aficio MP C2051 Color Copier wDOC...
    Jan 07, 2010 | Ricoh Office Equipment & Supplies
    CAN ANYONE TELL ME WHERE THE USED TONER BOTTLE IN A RICOH RW240 IS?
    Unscrew both the right hand side panels of the printer and you will see the bottle
    Oct 27, 2009 | Office Equipment & Supplies
    Lexmarkx125 will scan larger pictures but smaller ones.
    Here are some instructions from the Lexmark X63 which was similar to the X125.
    The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
    • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
    • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
    Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
    Ricoh CL7000
    Do a stop test using a document with CMYK content across whole document. Remove and examine M dev and drum and also check the master belt etc. The first component with the pink line on is most likely the faulty one.
    Aug 20, 2008 | Ricoh Aficio AP3800C Laser Printer
    Error Log Cannot store data of this size. Document Server
    The document server portion of the copier not only has limitations to it but it has compatiblity problems with it as well when dealing with mulitiple pages. The SODIMM card could be set for 64mb on your copier and the buffer is too small to work with it. It doesn't work the same way as a fiery server does on todays copiers.
    Ricoh tech support has told me there are three ways to use the scanner:
    1) Scan to e-mail.
    2) Scan to ftp server.
    3) Scan to document server using a seperate PC as the server.
    4) Scan to a local computer using Desktop Binder.
    www.ricoh-usa.com has software to do 3 and 4. #1 can be setup by adding the smtp server to your copier in the file interface section by pressing the user tools/counter. You have to have the IP address to the smtp server in order to get it to work. You can contact your internet provider to get that.
    Using the document on the copier is for temporary storage and isn't designed to handle big jobs to it as well. You can experience storage problems as well if your print server is full or you are storing faxes to the memory.
    The memory can be updated to the copier as well. It can read a SO DIMM PC100 card up to 256 MB. It's an older memory module that they use on older notebook computers. You can get them at computer stores or get them through PNY.com.
    Aug 18, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
    How do you set a scanned document folder on a ricoh aficio 1045?
    Thank You,
    Mikey
    Apr 03, 2008 | Office Equipment & Supplies
    23 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    fares
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
