Question about Home
CENTRIOS ROTARY DESK CLOCK 6311408. How to replace the battery. It appears I need to remove the swivel base, but I'm not successful & don't want to damage it. thank you
  • 4 Answers
SOURCE: Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Posted on Dec 26, 2007
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
  • 60 Answers
SOURCE: LG swivel base
Just look at where the base goes in. There should be 4 screws that are holding it on.
Posted on Apr 21, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
jan mczeal
  • 632 Answers
SOURCE: How do I remove the swivel base?
Steps to remove swivel stand:
  1. Carefully place the product screen side down on a cushioned surface that will protect the product and screen from damage.
  2. Remove the 2 screws that are vertically in line next to the power socket.
  3. Remove the 2 screws that are vertically in line under the RGB socket.
  4. Pull the stand out from the bottom of the TV.
  5. Reinstall the stand in reverse order.
Posted on Nov 03, 2009
I have a centrios clock that has an alarm, tells the time and temperature. I need the manual for it
So you worked out you need to specify a make :-)
Try these instructions or post to this forum. If you provide a model number for the clock which should be underneath it or at the back, I will try to find the specific model. They seem to make a few models. Post as a comment to this posting rather than starting a new one. Thanks
http://mb.nawcc.org/showthread.php?107852-Centrios-Atomic-Clock-Instructions
Nov 04, 2015 | Centrios Televison & Video
What is a rotary shaver?
Electric rotary shavers use a cutting system based upon circular blades which rotate under a slotted head. Electric rotary shavers may contain up to three rotating heads. The heads designed to swivel with the contours of your face.
Feb 06, 2013 | Health & Beauty
How to set the time on Centrios atomic clock?
I had the same issue. This s a great clock radio, but not very intuitive. I've uploaded a PDF of the manual from my clock radio, I hope it is useful.
Nov 30, 2012 | Centrios Audio Players & Recorders
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Nov 08, 2007 | Audio Players & Recorders
Home Logo
56 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
