Question about Canon m11055 - Dr2050c High Speed Scanner
When I install Canon DR2050/2080 and running the adjustment tool a message has appeared there is no device although the scanner mp237 has attached to the computer and in on condition.Please clarify
A dark portion has come in the middle of the scanned image
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Posted on Apr 23, 2008
  • 1335 Answers
SOURCE: how do i install TWAIN drive
Go to
http://www.usa.canon.com/consumer/controller?act=ConsumerHomePageAct
put in your model number and you will find the correct driver for your scanner.
Please make sure to rate this solution. Thanks.
Posted on Jun 09, 2009
  • 17 Answers
SOURCE: Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Posted on Jun 11, 2009
mohanchennai
  • 490 Answers
SOURCE: Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Posted on Sep 10, 2009
taiso67s75
SOURCE: Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Posted on Sep 11, 2009
Canon mp237 error 5011
canon pixma mp 237 macet dikarenakan tdk bs dibuat ngeprint...problemnya dari error code 5011
Jan 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
Scanner produces streaks
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Jun 29, 2010 | Canon DR-2050C Path-Through Scanner
Black line on image
Nov 08, 2009 | Canon DR-2050C Path-Through Scanner
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Cannot communicate with scanner message
Try an get a USB 2.0 printer cable. Some of the Canon scanners will not communicate quick enough without one.
Nov 03, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Won't install downloaded software from Canon
The software unzips to 'C' drive and should locate itself to the appropriate areas.
I suggest you get onto Canon support for this one.
Nov 01, 2007 | Canon CanoScan 8400F Flatbed Scanner
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon m11055 - Dr2050c High Speed Scanner Logo
59 people viewed this question
old marine
old marine
