Question about Bose Audio Players & Recorders
I have Bose 321 GS series 3. Dvd worked ok. DVD now only get sound no pix and blue screen. Replaced HDMI no change. Unplged all components no change. Bose screen reads "communicating with TV".???
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
SOURCE: bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Posted on Oct 12, 2009
  • 8546 Answers
SOURCE: I have the Bose 321 GS II, when watching a dvd we
You have to run an audio path with RCA cables from the TV (or the cable box, as applicable) to the Bose, then disable or turn down the TV volume.
Posted on Nov 30, 2009
SOURCE: Bose 321 GS III system says communicating with
I am having the same problem. Please help!!!
Posted on Jan 24, 2010
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
My bose 321 does not have sound when playing a dvd
The lazer is not reading the disc any more, It will have to be replaced,
Sep 21, 2012 | Bose 321 GS series II
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Apr 28, 2011 | Bose 3·2·1 II System
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
Dec 15, 2010 | Televison & Video
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
Bose GS 321 HDMI issue. I've had this unit for 6 months using the HDMI connection from the Bose to my HDTV for watching DVD's and its been working without issue. Last week I try watching a DVD. I change...
Hi, did you manage to fix it? I have the same problem. Would appreciate if you can share some results if you have any.
Many thanks, Jeffrey
Mar 08, 2010 | Bose 321GS Series II System
BOSE 321 DVD movie movie picure is blue. Its connected to a Sony LCD digital Wide screen TV Bravia Model KDL 40V2500 and my cable box. Could it be a loose connection.
Sounds like you are using a component cable(red,green,blue) rather than an HDMI cable.
Component cables are fine to use but if one of the 3 cables is disconnected, loose or bad, you may see blue video.
Check for loose connections or bad cables and make sure the proper color is plugged into its matching color.
Oct 25, 2009 | Bose 3·2·1 II System
Unlock code bose 321 GS III series
1. Insert a DVD which does not work due to region code error, then
2,.- Press right arrow
3.- Press up arrow
4.- Press Shuffle Button
5.- Press Stop Button
6.- Press and HOLD Mute Button
The tray disc will open and the will close.
Thats all....the Bose DVD media will be Multiregion....
May 30, 2009 | Televison & Video
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
41 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
