I have tokyo gas heater model MA-A430TFH. It switches off after 1 minute.can somebody help me.I don't understand it's user panel as well.can somebody translate it in english for me thanks
SOURCE: toshiba w47t english user manual
I cant change my langauge to english while my mobile toshiba w47t is in chinese language.
Posted on Oct 22, 2010
  • 232 Answers
SOURCE: I have recently bought a
http://service.us.panasonic.com/OPERMANPDF/KXTG6411-MUL.PDF
or
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/Operating-Instructions/model.KX-TG6411T.O#ts
Posted on Mar 03, 2011
  • 19 Answers
SOURCE: User Manual in English
The "LG SB260" has a webpage.
See; > http://www.lgtool.net/phones/SB260.html <.
You should find what you need there.
sl0j0n.
Posted on Jul 27, 2012
vvusmc3_9
  • 17 Answers
SOURCE: Where can i get operating instruction manual in
Try this web site. www.tokyo-gas.co.jp Key thing on these type of heaters-they take a lot of fresh air to run properly. If not, you coulkd wind up with a very sick house and sick people.
Posted on Dec 31, 2014
whpete44
  • 484 Answers
SOURCE: ;my heater is printed in Japanese which I can read. I need an operational mannual for gas fan heater Model MA-A630TFH which is made by Tokyo Gas Japan
Try taking a digital picture of it then transfer the text from the picture to the google translate site if possible.
Posted on Jan 15, 2015
Where can i get operating instruction manual in English language for heater TOKYO GAS MA-B350FH
Dec 31, 2014 | Cameras
How can we ignite the pilot switch
The directions are on the inside cover of the water heater as well as on the paperwork you received with the unit.
If you have none of these, get the make and model number of the unit and look it up on the internet.
General directions to light a gas appliance:
1.Turn the switch to, "Off"
2.Remove the 2 panels at the base of the unit.
3 Identify the pilot device.
4.Get a long lighter or match on a stick that reaches the pilot.
5.Turn the gas knob to the, "Pilot" position
6.Light the match and put it next to the pilot while pressing down the knob
7. Keep the knob pressed for about 45 seconds after the pilot lights
8. Let go of the knob so it's in the, "up" position
9. Turn the knob to the, "On" position
-the water heater should fire up in under a minute.
10. Put the metal panels back into position.
Jul 14, 2014 | Honeywell VR8200C6008
Tokyo gas fan heater user guide rn-a120fh-wh
Hi can u please send me the translation operation buttons in English language of RN 240 TFH fan heater manufactured by (Tokyo Gas) thanks.
Dec 12, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi i need English Language manuals for Osaka Gas Fan Heater Model 43-659... as the operating buttons of the heater is in Japanese Language. by mis handling it i got its timer ON. now dont know how to fix...
I have gas fan heater made by Tokyo Gas, model MA-A630TFH.
on the front pannel all the language is jAPENESE. PLEASE HELP ME AND MANAGE FOR OPERATIONAL MANNUAL IN ENGLISH.
Oct 20, 2012 | Heating & Cooling
Goodman gas furnace high limit switch
A volt/ohmmeter is only $3 at a place like Harbor Freight. Goodmans are known for overheating. Often the overheat switch is a one shot item that needs to be replaced every time it throws.
Think if it more like a fuse that melts.
Nov 10, 2011 | Heating & Cooling
I installed a new Pentair mini max heater 1yr. ago. I've used the heater about 10 times. I haven't used the heater the past 3 months and went to use it and the heater won't come on. I hear the blower...
An E04 can be alot of things.
If the fan is working, then the first thing to check would be the air/fan switch, or the air switch tubing itself. They installed the air switch tubing right over the burner tray so it melts and cracks quite often. This is one of the readons this model was discontinued.
The air switch is inside the cabinet on the right side behind the little metal box. remove the screws to access. The air switch is about 3" and round with a vinyl 3/8" tube coming out of it.
Also remove the top side panel on the right side. Now follow the air tubing from the switch to the blower in the side panel. Remove this tubing and inspect. Chances are there are som small cracks and things you will find. If this is the case, replace the tubing and try to restart heater.
If you did not find the tubing to be bad, then its your air switch. I would like to list the part number, but the model and BTU's were not provided above. Here is a link to the manufacturers parts and manuals list.
http://www.pentairpool.com/pool-owner/manuals/section.php?s=28
Hope this helps
BTW, a 1.5" gas line might be too much gas if its run all the way to the heater. As per the manual, 1.5" can be used up to 10 feet from heater, then bush down to 3/4". Gas pressure should be checked before and after the gas valve to ensure that the correct pressures are there. Pressure guidelines can be found in the above manual and should be followed strictly.
Apr 26, 2011 | Pentair Pool & Spa
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
