How o replace ac condencer - Heating & Cooling
WHY does it not cool for more than 10 minutes, than shutsoff
low refrigerant charge look at the sight glass if you see bubbles your low on freon. check your condencer coil outside clean the coil with condencer coil cleaner spray on wait 10 minutes hose off. most times a dirty condencer coil is the culprit
Jul 28, 2014 | Carrier 519exx042000aaaa 3-1/2 Ton Ac/hp...
How do i change ac condencer
First thing you have to do is harness the a.c gas in some kind of pressurized container so as not to release the toxic gas into the environment. Than just un -bolt the bolts probably you have to remove the front grill first.
Jul 10, 2014 | 2006 Peugeot 207 1.4
Ductless AC 3 unit split system problem
They piped it wrong. They mixed up 2 of the pipes at the condencer.
Jun 21, 2013 | Heating & Cooling
2000 vw Jetta ac not cooling, ac compressor is on, freon level good, with ac manifold gauges high and low side fluctuates from 50-60 psi on low side.
try to throw cool water on the condencer front of the engine radiator and see whether any cool air comes in the car. If so see whether the pressure valve is working okey or not because might the pressure is not sufficient.
Sep 05, 2012 | 2000 Volkswagen Jetta TDI
Every time I turn on the air or heat when the car is running My power steering iseffected and a loud screech? But not when the car not running (blower motor works) I think it is the ac condencer?
you need to replace the serpentine belt and perhaps the belt tensioner. When a heavy load is put on the belt, like turning on the AC, the drag may stop the belt from turning. This would stop the power steering pump from turning causing a hard steer condition. The belt is not gripping the pulleys tight enough. This is due to a worn out serpentine belt or worn out tensioner. If the AC works( cools the car) then replace the belt. If this does not cure the problem then replace the belt tensioner as well.
Nov 19, 2010 | 1998 Plymouth Neon
Ac blowing hot air
you may be low on freeon a vaul stem may be leaking it seems to be comon on most ac's
Aug 24, 2010 | 2002 Kia Sedona
Heat works but ac dont
Does unit do this when you turn the fan to the on position. If so you have a bad fan sequencer. Posibly
Jun 14, 2009 | Goodman CKL24AR24 Air Conditioner
I have a 2005 Honda odyssey. When I turn press the rear A/C button, the whole A/C system blows warm air and the a/c doesnt get cold at all....Is this a clogged hose or something??...
Hi i have 06 exl odyssey and i had SAME problem it was like this you turn on front ac and it works and when you turn rear ac then they both blow hot air . What is was a rock hit ac condencer . dealer replaced condencer it was like $700 bucks do not go to dealer just buy condencer for $120 online and it easy to change it and then refill with freon Also after that I put mrs grille on my odyssey . looks good and no problem at all Those condencer are common problem JUST DO NOT GO TO STEALLERSHIP
Apr 13, 2009 | 2005 Honda Odyssey
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
