Question about Drills
Need a pdf manual for PlasPlug Model DSH402US Drill Bit Sharpener
I dont know how to change the drillbit in my dw257 corded drill
Do you mean the Dewalt DW257 drywall screwdriver? For that model, you need to pull the adjustment collar forward. (This part fits over the drill bit to the clutch housing.) Remove the collar completely. Then using pliers, if needed, pull the drill bit tip out of the holder. Then put a new tip into the holder. Then snap the adjustment collar back over the retaining ring. See Figure 3 on page 2 of the manual (see below for a link) to see what the adjustment collar looks like.
If you want to replace the bit holder and the drill bit tip, pull the holder straight out from the drill. (Again use pliers if it is tight.) Then push a new bit holder into the spindle until the ball lock snaps into the groove of the bit holder shank. Put in the bit tip. Then put the adjustment collar on and make sure it snaps into the retaining ring.
These are the directions for the Type 3 DW257. The manual is available here: . From the Product Information tab, select your model type and the instruction manual will be shown in the right hand column, if it is available. The manual is available as a PDF; you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Oct 04, 2013 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Need a manual for bosch drill sharpener s40
Go to this site next scroll over to were it says more at the bottom you can chat with a Bosch tech.
Jun 26, 2012 | Drills
I need the instruction manual for using the Chef's Choice 300 knife sharpener please.
I could not find a complete instruction manual online for your product, but here are some links from the EDGECRAFT ONLINE SUPPORT page for your model:
Good luck, hope this helps a bit.
Apr 21, 2011 | Chef's Choice Flex HoneStrop Knife...
I have a plasplugs compact drill sharpener with chissel, knife and scissor sharpeners but there are no operating instructions. How do you use it?
Hi Rick,
You can go to this webpage and get the pdf document with your operating instructions:
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Garden
Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 14, 2009 | Drills
Require a manual for an ''efco'' chain sharpener.
There are no "efco" chain sharpeners at Northern Tool or at There is a Chinese made grinder with the Northern Tool name on it. It is a lessor quality copy of an Oregon model 511A. It is such a good copy that parts and the manuals are interchangable. The 511A manual can be downloaded here:
Lou --> -->
Apr 04, 2009 | Northern Tool Garden
Need part for bit sharpener model 263 type 1
I have been unable to locate
Aug 31, 2008 | Drills
Drills Logo
330 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
