Question about Sewing Machines
I changed the needle and now it is not pitching up the cotton wool from the bobbin, what can I do.? Thank you.
  • Sewing Machines Master
  • 11,506 Answers
Check to make sure you installed the needle correctly and that you have the right kind of needle for your machine. If it is turned the wrong direction, it will not connect with the bobbin thread.
Otherwise, the machine may be out of time. Search sewing machine timing or take it for service.
Posted on Dec 09, 2016
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
Aug 19, 2016 | Sewing Machines
My brother LS-2725 is sewing perfectly on surface but has large loops underneath.
Three main reasons for this issue:
  • The cotton is not threaded correctly> Cotton not in tensioner correctly, cotton threaded through needle backwards etc..
  • Bobbin not seated properly so not allowing cotton to loop over smoothly.
  • Bobbin carriage is damaged (usually by forced needle hitting it) Usually this is the tip of the pickup on the carriage is bent.
Hope this helps.
Jul 14, 2016 | Brother Sewing Machines
Bobbin thread bunching on singer sewing machine...have changed needle and tensions! Help
Try a ball point 11/70 or stretch 11/70 needle. Also rethread the entire machine. Make sure the needle is inserted correctly in the sewing machine. I had this same thing happen to me recently and I found I had the needle backwards.
Aug 06, 2014 | Singer Featherweight 221 Bobbin Case,...
How do I put cotton on machine
Paul... youtube it.... It's really not difficult. Have to load bobbin with thread first... install bobbin (under the needle plate in its holder) thread cotton from top of machine through the correct catch points to the needle.... catch the thread from the bobbin..... pull threads under pressure foot (but look in youtube... loads of vids)
May 16, 2014 | Janome Sewing Machines
Thread nests
try changing the needle--make sure the needle is turned the right
way--and that the needle is the correct one for the fabric being
sewed--example--cotton fabric take one kind of needle and stretch
fabric take another kind of needle
try rethreading the machine top thread and bobbin
make sure to use every thread guide
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
if the bobbin and bobbin case have to be inserted togeather,,
make sure that the bobbin case is secure and snug in the machine
make sure the thread does not come off the thread take up lever
Nov 04, 2012 | Brother InnovIs 4000D Computerized Sewing...
My machine is not sewing underneath just large loops of cotton and then it stops sewing altogether, any ideas please. thankyou
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
also adjust the top thread tension until the stitch looks correct
check the bobbin to see if it's warped
clean under the needle plate & in the bobbin area for loose threads or
Jun 10, 2012 | Sewing Machines
Lots of possible issues, but first, check your bobbin case. Take the bobbin out and clean around the inside with a cotton bud. Replace the bobbin and hold the thread and let the bobbin/bobbin case dangle free (take care that the bobbin doesn't slip out of the case. The bobbin case should stay stationery. If you **** the thread upwards , the bobbin should unwaind (this is a very very rough guide). If the bobbin unwinds when just holding the thread stationery, screw in the tension screw on the side of the case a fraction until it doesn't. Conversely if it doesn't unwind when jerked, try unscrewing it slightly. The adjustment is fairly critical and should really be done with a proper gauge and weights. If the bobbin tension is OK, are you sure you're threading the top thread properly ... you should always thread through the pre-tensioner, tension discs and takeup arm with the presser foot lifted - this ensures the thread will lay down between the tension discs properly. Put the presser foot down only when you're threading the needle. If the top tension is too high, try cleaning the tension discs - you can do this fairly simply by turning the tension down to 1, or 2 and with the presser foot up, thread some thick wool through the pre-tensioner and tension discs. Drop the presser foot and drag the wool through slowly - this should clean the fluff and muck out of the discs. Failing the above, you may have a problem elsewhere, such as the check spring or maybe even a problem with the hook/shuttle. In this case, you'd be best to have it checked-out professionally. By the way ... when did you last have your machine serviced ???!!! Also, when did you last remove the hook/shuttle, clean round the hook race firmly with a cotton bud and re-oil it ? You may find the latter will cure your problems ! Good luck and get back to me if I can be of any further help.
Feb 08, 2012 | Sewing Machines
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
Bobbin case turns in its place
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
Jul 14, 2008 | Singer 7422
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
