Question about Exercise & Fitness
My Lifestride 5500 will not incline.
While pressing the arrow, the display changes making it appear to be working; however, when using it - it does not incline to that set number and the incline number flash is zero.
  • 6,694 Answers
You have to check the limit switches of incline. Also the incline motor.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 23, 2016
Treadmill
Try to RUN the software calibration for troubleshooting.
However test the elevation motor, Lube THE MOTOR : shaft +gear+adjust the small POT for increase performance. see the diagram attached.
Feb 04, 2013 | Life Fitness Lifestride 9000 HR...
Tip
How to Change the Display Settings for your MP3 Player |
You can personalize your music player by changing the appearance of your background. This will also help you to read the screen while making the icons easier to see.Follow the instructions below to change the display settings on the device.
Instructions:
Things You'll Need:Owner's manual,mp3 player
1.Turn on your MP3 player and use your keypad to select "Setup." Push the center button on your keypad to highlight "Display" on the Setup menu.
2.Use the keypad to scroll though the languages on the Display Menu. Push the center button on your keypad to choose one.
3.Scroll down the menu to the "Brightness" options. Press the right arrow on your keypad to increase the screen's brightness, or press the left arrow to dim the screen.
4.Scroll down to the "Wallpaper" selection on your Display Menu. Use the arrows on your keypad to scroll through the different backgrounds for your MP3 player.
5.Change the icons on your MP3 player. Scroll down to "Appearance." Use the arrows on your keypad to scroll through the different icon choices.
Tips & Warnings:
Make your own background by downloading photos from your computer.Dim the brightness in low light situations to save battery power.
on Feb 10, 2011 | Audio Players & Recorders
Treadmill belt runs too fast and will not power off with control panel
Step 1:
test the speed sensor,m for open or faulty, clean it, and tight the connector. see the diagram attached.
However follow the steps for RUN the.s calibration for fix it.
God bless you
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 07, 2013 | Exercise & Fitness
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    I am trying to change the names that appear on my phones i.e. people who have left but names still appearing
    To change the names in the telephone system you'll need to enter programming.
    Programming is done on 7310, 7324 and 7316 type sets.
    Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt, press the show key (top right arrow).
    The display should now ask for an extension number.
    Enter extension number you want to change the name on.
    Press the show key (top right arrow)
    The display should say LINE ACCESS
    Press the next key (bottom right arrow) .
    The display should say CAPABILITIES.
    The display say Name.
    press the Chng soft key.
    use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
    ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
    Press the next key (bottom right arrow) to enter the name.
    Press the release key when finished
    Jan 19, 2011 | NorStar BCM-T7208 Corded Phone
    How do I change the Baud rate on a canon f80 fax
    To set the receive speed
    Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
    1. On the operator panel, press <Menu>.
    2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
    3. Press [Set].
    4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
    5. Press [Set].
    6. Press the right arrow repeatedly until [RX SETTINGS] appears.
    7. Press [Set].
    8. Press the right arrow repeatedly until [RX START SPEED] appears.
    9. Press [Set].
      1. The factory default RX (send) Speed is 33600 bps.
      2. You can select from the following RX Speeds:
        14400 bps
        9600 bps
        7200 bps
        4800 bps
        2400 bps
    10. Press the right arrow to display the applicable RX Speed.
    11. Press <Set>.
    12. Press <Stop> to return to standby mode.
    To Set the Send Speed
    Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
    3. Press [Set].
    5. Press [Set].
    6. Press the right arrow repeatedly until [TX SETTINGS] appears.
    7. Press [Set].
    8. Press the right arrow repeatedly until [TX START SPEED] appears.
    9. Press [Set].
      1. The factory default TX (send) Speed is 33600 bps.
      2. You can select from the following TX Speeds:
        14400 bps
        9600 bps
        7200 bps
        4800 bps
        2400 bps
    10. Press the right arrow to display the applicable TX Speed.
    You can download a copy of the user manual for the F80 at
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
    Please make sure to rate this solution. Thanks.
    1. Press <Set>.
    Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
    Lifefitness TR 9000 treadmill - 1997 model
    Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
    Apr 28, 2010 | Life Fitness 9000 Next Generation...
    THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
    Programming is done on M7310, M7324 and T7316 sets.
    To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The 4 top line/feature keys are now used for programming2.gif.
    The display should now ask for an extension number. Enter extension number you wish to program ringing on.
    The display should sat LINE ACCESS
    Press the show key (top right arrow) .
    The display should say LINE ASSIGNMENT.
    The display ask for a line number. press list
    The display should say line 001: appear only
    press the Chng key till it says appear & ring
    press next key (lower right arrow)The display should say line 002: appear only
    repeat procedure for remailing active lines
    If your system uses the older programming template,
    then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    the display says A. Configuration
    the display will say1. trunk/line data
    the display will say 2.line access
    the display will say line assignment
    Press the next key 2 times(bottom right arrow) .
    The display should say ringing.
    Press the show key (top right arrow).
    the lines should be listed as appear only change to appear and ring
    press Rls when finished
    Oct 23, 2009 | NorStar M7208 Corded Phone
    How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
    Sets that are programmed to ring should automatically have ringing line preference.
    press the heading key (top left arrow) til the screen says terminals&sets again
    Prime line assignment is also programmed at the terminals&sets prompt.
    press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
    The display should say Line Access
    The display should say Line Assignment
    The display should say Line Pool Access.
    Press the next key (top right arrow)
    The display should say Prime Line
    Press the Chng soft key till you get to the desired line or pool to pick up on
    Oct 19, 2009 | NorStar Meridian M7310 Phone
    Exercise & Fitness Logo
    77 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
