Question about GE 13TVR60 Combo
My Technika television will not turn on, it has a blue flashing light as if on stand by can someone please help
Technika television
its an error in the power supply board.
Aug 19, 2008 | Televison & Video
Technika lcd 32-207 television powers up but will noit come on blkue light keeps flashing
Hello.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Dec 06, 2012 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Blue flashing light. will not turn on at all.
Hi.
If the TV stays in stand-by, with the LED light on, but does not respond to remote, or to the buttons on the chassis, then that means that the TV has gone in protect (safe) mode because an internal fault had been detected.
Follow the basic troubleshooting on this article: Why my TV does not start up, by disconnecting power cord and connected devices. The article is for rear projection TVs procedure is same on CRT, LCD and Plasma TVs. Disconnect power cord for at least 30 minutes, and test using different connected devices.
If that does not work, then a technician must test the TV and replace the faulty component. In that case contact the support number listed on the owner manual to get the TV repaired by a licensed technician.
Regards.
Mar 14, 2010 | Televison & Video
Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Jul 09, 2009 | Televison & Video
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
GE 13TVR60 Combo Logo
252 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
