Question about Stoves Ovens
I need a manual for model no sn90fp stoves new home
Traditions the earth stove. how to operate
Try these people who seem to be main dealers.
http://woodheatstoves.com/stove-manuals-earth-stove-user-manuals-c-291_217.html
Nov 03, 2015 | Us Stove Company USSC Eco-Aire Window...
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 | Ovens
Need knobs for Lady Kenmore free standing stove. do not have model # stove was installed when home was built in 1990
parts need to have the model number sometimes the part with have the number etched on to it
Feb 01, 2015 | Kenmore Ovens
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
I have just got a new stoves cooker and i need the manual for it, the model number has worn away a bit but from what i can see this is the model number 039850512
If you contact STOVES with that number, they should be able to help you. If you want a copy of my 720EF manual, supply an email address and you can gave a copy.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
Manual for cooker
just wondered if u ever managed to get a manual for the stoves new home 600 si dlm ? if so,could i be cheeky and ask u to email me a link please?
thx in advance :)
Ant
flatlanderuk21@yahoo.com
Mar 08, 2009 | Stoves Ovens
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Glass for stove
You need the full model # off the range not the owners manual
Jan 09, 2008 | Ovens
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
