SOURCE: Hi, I took off my car
Dear Memo,
you can download the manual for this ,player, from this site:
http://www.devicemanuals.com/guide/Car%20CD%20Changer/Kenwood%20French/Kenwood-French-KDC-MP625-CD-DVD-Changer-Owner's-==TVRFd05qVXk=.html
in this manual you can get the security code for this Player also.
Cheerup and be happy always
SOURCE: My Facebook was hacked and I can't log in tried
Consider contacting them again for a new code.
ID-CODE
ID Code Setting
Prior to operating this unit, it is advisable to assign a 4-
digit ID code for security. Once the ID code has been set,
the unit cannot be operated if the main power supply is
disconnected then re-connected. It is electronically locked
so that a thief cannot use the stolen unit unless that person
knows the code you have set.
The ID code operation must be performed only by the
person to whom the unit belongs.
Generally, it is not necessary to enter the ID code each
time when using the unit if it has not been disconnected
from the main power supply (car battery).
to 4 digits numeric code
default: none
How to set your ID code (for the first time)
q Enter an 4 digit ID code.
w Enter the same 4 digit ID code again.
How to change your ID code
q Enter the preset (old) 4 digit ID code. If the wrong ID
code is entered, a new ID code cannot be registered.
w Enter a new 4 digit ID code.
e Enter the new 4 digit ID code again.
How to cancel the known ID code
code is entered, it is not possible to cancel the ID code
function.
w Touch and hold until "COMPLETED!" is displayed.
The ID code canceling procedure is completed.
The unit now works without an ID code.
Note:
¡Should your unit ever require service, cancel your ID
code before sending for repair.
¡The ID code setting cannot be eliminated even by the
memory clear function.
¡The inputted code is not displayed for your security.
0 9
Caution
¡Record your registered ID code and keep it in a
secure location. (Fill in the ID code memo (a
page 46).) If you forget it, you will be unable to use
the unit. In case you forget the ID code, please
consult your nearest Panasonic Service Center.
