Question about Tablets & eReaders
Camera shows in left corner of screen always but when i go to app or click left corner it tells me cannot connect
2 Suggested Answers
faithrauquel
  • 6 Answers
SOURCE: Both cameras has stopped working,help
Maybe you can try pressing and holding the power button until it turns off then keep holding it until it turns back on and see if that works
Posted on Jan 01, 2014
Testimonial: "i tried it several times, for shure... no success, i am not an expert in hardwares/softwares, but not a newbie too... i tried all i could think about, but thak you for the idea"
Have echo and new apple i pad how do i install it to get wifi. i have 0 knowlwdge
Follow the small sheet of instructions that came with the ECHO.
if you want to hear music (and other audio) in stereo, attach a separate pair of stereo speakers to the 3.5 mm jack on the back of the ECHO (I'm assuming it has one like my Echo Dot does).
you may have to push the 3.5 mm plug in hard for it to connect to both stereo channels on the cable. If you only hear sound out of your left speaker, both channels aren't connecting. Disconnect and reconnect the 3.5 mm cable a few times, being sure to push it in hard. This will loosen up the jack so that the plug connects easier and correctly.
On your iPad, open the App Store by tapping its icon.
in the search box at the top, type Alexa.
From the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app. When the app opens, click on the "3 horizontal bar" icon in the upper left corner. A menu will drop down. Click Settings. Then, click SET UP A NEW DEVICE , and follow the instructions.
Nov 14, 2017 | Apple Tablets & eReaders
My iPad app icon shows at seven but when I go into it to see what needs to be updated, nothing is listed for updates. What is the seven on the icon for? I just downloaded 11.02
The 7 showing means you have apps that need to be updated. Click on the update app and on the next screen click on all available updates which probably will be at the upper left corner. When you select that, the apps that need to be updated will appear. These are the updates for the apps and has nothing to do with IOS.
Oct 10, 2017 | Tablets & eReaders
How do I remove/delete the CNN app from my Apple iPad?
You should be able to delete CNN app from Home screen on your iPad directly. The following steps below will show you how to do.
1. You only need to keep touching the icon of the CNN app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the app deleted with no efforts.
http://www.leawo.org/tutorial/how-to-delete-apps-from-ipad.html
Jan 17, 2017 | Apple Tablets & eReaders
Some how the camera got deleted from my kindle fire 6hd, can we install it again?
You need to update your Kindle Fire HD to the latest firmware (7.2.3 at the time of writing).
Once your device is up to date, you can access camera app (with basic functionalities) clicking on Photos in the carousel. As soon as Photos starts, you should be able to find a small camera icon in the top-notch corner of the screen. That gives you access to a stripped-down app.
The installed camera app sports several added features, which have been blocked for some unfathomable reason. To access those, you need a modicum of fiddling: install ES File Explorer from Kindle App store (free app), then click on App Manager, Category, choose all apps. You'll see all the installed apps. Tap on camera and voila, you get the stock Camera app with full functionality..NOT SURE IF THIS WILL HELP YOU OUT BUT ITS ALL I COULD FIND.
Nov 07, 2016 | Tablets & eReaders
How to delete unwanted music
is it a galaxy samsung tablet ?
in apps find an app labelled as my files with a folder icon above it
under root/sdcard/music
find music file click on the little box left of the file you wish to delete
a green tick will show in the box
once you do that you will notice at the top of the screen a dustbin icon has appeared in the right top side. press this icon to delete the file. then click on yes when it asks if you want this item deleted.
Then double click back icon to get out of my files
back icon is bottom left corner on black part of screen.
Mar 18, 2015 | Samsung Tab Tablets & eReaders
How do I delete watch latter videos all at once or do I have to do it one by one
The question is oddly worded. If this doesn't answer your question, you might try more carefully explaining what you'd like to do.
If you would like to delete multiple videos that you have taken with your iPad, and you are using iOS 8, you can:
  • Launch either the Photos app or the Camera app
    • in the Photo app, touch the last picture taken in the lower left corner of the screen
    • Select "All Photos" in the upper left corner of the screen
  • Choose the group of photos and videos you would like to work with
  • Touch "Select" in the upper right of the screen
    • touch each photo or video you would like to delete
    • touch the garbage can icon in the lower right corner of the screen.
Feb 19, 2015 | Apple iPad Mini
How do I delete an app from my ipad when it does not show the x
The App that you are wanting to get rid of is more than likely a built in App. All Apple iOS devices ie iPhone, iPod, iPad, iWatch come with pre-installed Apps, these apps unfortunately cannot be deleted, Apple does not provide any options with these built in apps to hide, remove or otherwise. ALL NON Apple Apps will always be able to be deleted, like you have mentioned by a wobbly widget and an "x" in the top left corner. Hope this information was helpful, if so please click the link below.
Sep 20, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
How to delete unccessery apps on a iphone 4?
You can directly delete apps from Home screen on your iPhone or iPad. The steps below will show you how to delete apps from iPhone/iPad directly.
  1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
  2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
How to Delete Apps from iPad
Mar 10, 2014 | Apple iPad 32 GB 3G Tablet PC
How to rotate asus tablet webcam display 90 degrees?
turn on the auto rotate screen and if that doesnt go in the top right hand corner there should be a button there, click on it and it says rotate just keep tapping it until it rotates to your desiered position.
Nov 30, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
