A line runs through what is printed. The name on the check and the check amount are not readable
About every 4th line is un readable
Hi, try cleaning the printer head via your pc ( use printer manual for maintenance). The other problem could be that the ink is running low. Hope this helps.
Apr 18, 2014 | Epson Stylus NX127 Multifunction Inkjet...
WHEEL IS STRIKING BUT NOT PRINTING...AFTER PULLING & PUSHING THE HEAD BACK & FORTH SEVERAL TIMES A TINY AMOUNT OF INK IS HITTING THE PAPER BUT STILL NOT READABLE
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Aug 08, 2013 | IBM Wheelwriter 30 Typewriter
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
My mp mP830 prints some lines (or partial lines) Consistantly misses the same rows each page
Sounds like the ink is running out at the same time each printing. Check the ink supply. The printer may not be letting you know the correct amount remaining. It could also be the ink jets themselves getting clogged and not distributing the ink enough to compensate for the amount of printing ink, on the page, in time to print all of it in succession. Do a test of no printing except where it seems to be missing and just print that area (print: selection).
Sep 16, 2010 | Office Equipment & Supplies
Epson lx 300 + # print not readable
if the print out is not readable.. most probably your print head pin is broken.. you can check your print head by removing it.. just unscrew the screw holding the print head and look at the front portion of the print head..over there are rows of pin.. see if the pin is even else it's broken..
May 21, 2010 | HP Color LaserJet 2600n Printer
Black Lines
you need to change drum
elvis
Apr 18, 2008 | Brother HL-5240 Laser Printer
Ink replacement has not helped print
Sounds like a damaged or dirty flex cable to the print heads. If those tiny contacts go bad, nothing will print properly. Check the cartridge and socket area for any dirt or dis-coloration. The connections can be cleaned with contact cleaner (from radio shack), and then dried with isopropl alcohol (use the purest you can find).
Jan 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
Not printing right
You need to run an inkjet printer maybe once a week or so, depending on the relative humidity of its location. You need to do a head clean, maybe change your cartridges - again.
Dec 22, 2007 | Lexmark X75 All-In-One InkJet Printer
24 people viewed this question
k24674
