Question about Dayton Heating & Cooling
Propane gas dayton 3ve59 heater will ignite then puff go out WILL not start the burner
2 Suggested Answers
SOURCE: Dayton 3VE59 Gas Utility/Portable Heater won't
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Posted on Feb 13, 2011
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
We have a late ignition on start up, we cleaned the burners and replaced gas valve and still has late ignition.
if it has a pilot light is this too small causing it to light with a bang is what you mean with late ignition ??
Aug 22, 2011 | Dayton (3E227) Gas Radiator Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Want to change a naturel gas to propane can it be done
yes you will need a kit to from nat gas to lpg reg spring burner orfice pilot orfice
Jan 17, 2011 | Dayton (3E133) InfraRed Heater
How to convert my heater from natrual gas to propane
you will need a converstion kit for nat gas to lpg try national enrgy they will suppy the parts you will need make , model number, serial number btu size , it will be a new pilot orfice , burner orfice and new reg or spring on the gas valve
Nov 16, 2010 | Dayton Gas Furnace Heater
Can you sucessfully convert a Dayton Model 3E368C,
The orifices have to be made smaller for propane. You have to go 10 drill bit sizes smaller. Also the air gap on them burners has to be tweaked. Primary air is added to the lp at the orifice. The gas/air mix has to be close or the nasty yellow smutty stuff happens. The gas valve needs to be set for LP gas pressure and the pilot orifices need to be changed. Nothing to it old man.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2009 | Dayton (3E386) Heater
Pilot lights but heater does notstart burning it sounds like everythings starting up its about 15 years old worked fine then one night smelled some gas shut it off next day would not work its propane
its most likely dirt/rust in your burner assy , but as its 15 year old and propane do your self a favour and get it inspected by a registered gas/propane engineer .
ive witnessed propane explosions at first hand and they are scary
Oct 23, 2009 | Dayton Gas Fired Heater LP TC200VA - Heats...
I have a dayton furnace model 3e368a serial c8425580 wondering if it can be converted to propane?
yes it can you must change the gas valve and the converter to propane,may have to change orafice on burners.any good plumber can do this for you.
Jul 11, 2009 | Dayton Gas Furnace Heater
Want to change Dayton 3E133E from natural gas to Propane
Would have to have conversion kit IF available. Must get from mfr. The Dayton brand is owned exclusively by W.W.Grainger. Not sure if someone else makes their furnaces for them. Start w/ Grainger, if they won't sell to you maybe they will give you the name of a company who will work on it. Good Luck!
Mar 09, 2009 | Dayton Electric Heater
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
May 15, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
