Question about Brother GX-6750 Typewriter
Have the same problem. Wheel does not line up with keys
Have changed wheel and still does not type correct letters. I have also followed directions as set in instruction for "resetting" the wheel.
    President:
  • 2,306 Answers
You have to loosen the screw on each side of the carriage that holds the silver guide and move it away from the font wheel. The factory adjustment is to put in 2 pieces of paper and adjust to be snug. Take out the paper and it should reset properly.
Posted on Jul 27, 2009
Olympia Startype 3 occasionally types double vertical line and spacing is changing between letters
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
Sep 15, 2014 | Olympia Startype 3 Typewriter
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
How to change the letter wheel and lne it up. It
Check the pitch switch selector be sure it isn't in PS.
DickyO
Feb 11, 2010 | Olympia Startype 3 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Jan 14, 2009 | Nakajima AE-710 Typewriter
Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Aug 21, 2008 | Olympia Mastertype 3 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
82 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
