Question about Craftsman Heavy Machinery
Craftsman 247.799630 with engine 143.966503-Tecumseh OHH55-69020B.What is the purpose of ground wire part no 110A?
I bought a Craftsman chipper Shredder Vacuum off Craigslist with a non starting problem. It's pretty clean and doesn't appear to have many hours on it. I've been troubleshooting it and it's getting spark and fuel but won't start. I'm thinking it must be a partially sheared flywheel key but not 100% positive that's the problem.
    Novelist:
  • 170 Answers
Easy enough to ck---pull flywheel that way you can eliminate it or fix it--also ck to see if it's been apart before by the marks on the screws/bolts--if so there may be other underlying issues--it one of those things that you have to be methodical when dealing with an unknown problem/operator etc etc----other thoughts valve hanging up or missing--broken cam---I could go on and on but you should get the pix
Posted on Nov 29, 2017
SOURCE: 9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
Posted on Mar 19, 2009
  • 91 Answers
SOURCE: 5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Posted on Mar 30, 2009
SOURCE: Can't start Chipper
Unplug the spark plug wire FIRST.  DO NOT SKIP THAT.  Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse.  I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards.  You have to disconnect the spark plug because the engine could fire when you turn it.  Even if it doesn't start, one good kick could hurt you pretty seriously.  So, go unplug the spark plug and do your thing.
Posted on Apr 19, 2009
Dolfoff
  • 148 Answers
SOURCE: looking for manual for craftsman chipper
The manual can be found HERE.
On the left side of the page, under "Browse Subcomponents" you can use your RIGHT mouse button to open each page in a seperate window. This reduces the use of your BACK button, and personally, I find it more convenient.
Hope this helps.
Dolf-
Posted on Oct 10, 2009
rwvanlue
  • 486 Answers
SOURCE: tecumseh chipper shredder-vacuum
How have you determined that there is no spark? Have you used a type of spark tester?
What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
If you do not have a spark tester, remove the plug, and with it connected to the wire,
find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
That age of unit should have electronic ignition, so if there is a 'no spark' condition, I would double check safety switches that are found on snouts, shrouds, bags, discharge chute, ect.
Get back with me on how this issue works out.
thanks, rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 12, 2009
Testimonial: "Thank you. I will check these mentioned location for saftey switches. Don Ellis 1-901-854-5556"
Need spark plug type and gap setting Craftsman 247.775870
Champion N4C, Gap: .030
Air filter: tecumseh 36046
Pre-filter: Tecumseh 36634
Jun 20, 2013 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Need new air filter for a tecumseh shredder chipper 10 hp
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Aug 22, 2011 | Tecumseh Heavy Machinery
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
I want to change the oil on my Yard Machines snow thrower with a 10hp Tecumseh engine and can't find the engine manual. What kind and how much oil should I use? Thanks - Zelmo
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Dec 31, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
Oct 12, 2009 | Craftsman Gas Mini - Tiller/Edger
Location of governor linkage and throttle linkage
Try going to searspartsdirect.com. You can put in the engine number 143.955016 in the model search and it should give you a parts list and diagram for that engine.
Good Day.
Brian
May 02, 2009 | Troy Bilt Walk Behind...
Heavy Machinery Logo
1,004 people viewed this question
Top Craftsman Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Tom Chichester
toddgilbert
toddgilbert
Are you a Craftsman Heavy Machinery Expert? Answer questions, earn points and help others
