Question about Samsung UN50EH5300 - 50" 5 Series LED-backlit LCD TV - UN50EH5300FXZA
Hello, i have the samsung smart hdtv model#UN50EH5300F .i have a upside down screen . which is very strange . can anyone help fix this
I've tried to reset everything nothing happen .ive done a software update nothing . is there a setting that i can do to un flip the screen
5 Suggested Answers
SOURCE: Pink picture with no green
take the color to b/w and retune
Posted on Apr 23, 2009
SOURCE: Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Posted on Jan 03, 2011
gopakumarg43
  • 74844 Answers
SOURCE: Hello I have a Samsung smart TV which has no picture image..just a black screen, it does have sound Model: UN40H6203AFXZA version UF04 .help please
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Jan 20, 2016
gopakumarg43
  • 74844 Answers
SOURCE: Samsung 3D tv model UN 60F7050 turns off/on every minute. Factory reset done but only works for short time then off/on again,again again
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Oct 21, 2016
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Jun 10, 2017 | Sharp Televison & Video
I have a Samsung 40 led smart tv... Model number UN40D6000SF.. The problem I'm having is when the boot logo is upside down tv will flash on n off. What is wrong with it??
Samsung say you should try the factory reset option.
If that doesn't work it could be a fault on the main board. Sometimes this happens when boards are replaced.
There is also a service mode that allows you to flip the main screen. You can find how to access that by searching YouTube with the words "Samsung TV picture upside down".
Try the other options first though.
Apr 04, 2017 | Samsung Televison & Video
I have a samsung UN55ES7500 and it makes a strange noise and turns off and then comes back on
amigo lo ?nico que puede hacer ese ruido es la fuente de poder revisala de ve tener un capacitor en corto o en fuga y dale mantenimiento a veces el polvo juega malas pasadas con las fuente de los tv por el alto voltaje q manejan yo tu buscaba ayuda profesional....
Jan 06, 2017 | Samsung UN55ES7500 55 Inch 3D 1080p Smart...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Hello, I have Samsung TV Model: UN60ES8000FXZA. I replaced the Main board, TV works fine, except the upside down picture. How to fix this problem, I need to get special codes.The same picture on the M
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 31, 2015 | Samsung Televison & Video
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Tv screen flipped over upside down
have u just replace the main signal board if so u need to contac a sansung service center , and ask for the code to puit normal
May 08, 2009 | Samsung HL-S5086W 50" HDTV
Samsung UN50EH5300 - 50" 5 Series LED-backlit LCD TV - UN50EH5300FXZA Logo
Henry  Thomas
Henry Thomas
